Normal Topic Tooltip on the node texts (Read 10188 times)
swapnil
Sep 28th, 2018 at 7:32am
I have below node structure. It has 3 ,4 rows of texts on which i need to show tool tip. Using container node but it has tool tip only for the heading. Any idea how to add tool tip for all the text rows?
Re: Tooltip on the node texts
Reply #1 - Sep 28th, 2018 at 9:05am
Are you showing these text rows using separate child nodes inside container? You could use TableNode and set cells' text and tooltips instead. Anyway child nodes' tooltips work for me when testing with container. Please attach saved diagram JSON so I can try this with same property values as yours.
reshma
Reply #2 - Oct 8th, 2018 at 6:40am
tooltip is showing on node but i have to set diagram.seEnable(true) and if set here true then my drag and drop functinality not working.
swapnil
Reply #3 - Oct 8th, 2018 at 11:55am
Hi Slavcho,
By which method can i set tool tip of the cell in TableNode?
Swapnil Thosar
Reply #4 - Oct 9th, 2018 at 10:01am
Actually you can't, we have cell tooltips in libraries for other platforms but turns out they aren't available in JavaScript diagram yet. We'll try to implement that for upcoming release.
Reply #5 - Oct 11th, 2018 at 8:59am
This version adds support for cell tooltips -
https://mindfusion.eu/_beta/jsdiag33.zip
table.getCell(0, 0).setTooltip("cell 0:0");
