Normal Topic MindFusion - Block diagram in javascript (Read 6462 times)
Brayanos
Oct 5th, 2018 at 11:22pm
I need to block the generated diagram so it can not be edited, how do I do it? Thanks in advance
Re: MindFusion - Block diagram in javascript
Reply #1 - Oct 8th, 2018 at 8:53am
Try calling diagram.setBehavior(Behavior.DoNothing);
Reply #2 - Aug 6th, 2019 at 4:22pm
Not sure if this is related to our diagram library. Do you mean using the diagram's SvgExporter and loading the generated svg into that tool?
