Hot Topic (More than 10 Replies) change color link and property (Read 15802 times)
Re: change color link and property
Reply #15 - Dec 24th, 2018 at 7:06am
The control invokes the method from previous point to decide what object to edit, and you can override it as shown to return whatever label is close to the double-click point when one is not directly under mouse pointer. If you are asking how to actually override the method, e.g. set AppletStartedScript to name of a function that should run when DiagramView has fully loaded on client side, and then call above code from that function.
Try setting labels' AutoArrange property to make them avoid the link sements.
Reply #16 - Jul 24th, 2019 at 12:52pm
Hello
I want to open or export an image for example (.svg) from an .xml file.
thanks
Reply #17 - Jul 24th, 2019 at 12:59pm
Try the Diagram.CreateImage method to export bitmaps, or the SvgExporter class for SVG drawings.
wincomhaj
Reply #18 - Jul 26th, 2019 at 6:58am
I want the generation of the image to be from a sourcer .xml file and not from a diagram
Reply #19 - Jul 26th, 2019 at 8:58am
Our API is for creating diagrams and any PDF / SVG / bitmap export has to go through a Diagram object. You can find some examples on generating diagrams from XML here -
https://www.mindfusion.eu/onlinehelp/flowchartnet/index.htm?CC_Miscellaneous_1.h...
