Normal Topic Force DrawBackground on range selector for WPF (Read 4923 times)
notsureusa
Oct 24th, 2018 at 2:00pm
The range selector DrawBackground event only gets called on resizing of parent container.  How would one force this event to be triggered without a resize event?
Lyubo
MindFusion team
Re: Force DrawBackground on range selector for WPF
Reply #1 - Oct 25th, 2018 at 8:57am
The event is triggered when the background is required to render (in a Control.OnRender override). To manually force it to repaint, find the element in the range selector's template and call it's InvalidateVisual method:
var bckgr = range.Template.FindName("PART_Background", range) as Control;
if (bckgr != null)
    bckgr.InvalidateVisual();
You can also try replacing the background control in the template with your own, and include your customization there.
Lyubo
notsureusa
Reply #2 - Oct 25th, 2018 at 12:33pm
Works great.  Thanks!
