Normal Topic ImageComponent Clicked event not fired when part of ContainerNode (Read 2099 times)
VM
Nov 7th, 2018 at 3:09pm
I have a ContainerNode that contains a CompositeNode.
CompositeNode has a StackPanel with an ImageComponent;
The following code does not generate Clicked event:
ContainerNode containerNode = diagram.Factory.CreateContainerNode(rect);
CompositeNode toolbarNode = new CompositeNode(diagram);
diagram.Nodes.Add(toolbarNode);
StackPanel panel = new StackPanel() { Height = 18 };
ImageComponent imgCmp = new ImageComponent() { Image = Resource1.add_menu };
imgCmp.Clicked += (o, e) => { MessageBox.Show("imgCmp"); };
panel.Components.Add(imgCmp);
toolbarNode.Components.Add(panel);
containerNode.Add(toolbarNode);
If I replace an ImageComponent with ButtonComponent whose content is TextComponent the events are fired.
If I replace an ImageComponent with ButtonComponent whose content is ImageComponent the events are still not fired.
Thank you in advance,
Vadim
Re: ImageComponent Clicked event not fired when part of ContainerNode
Reply #1 - Nov 7th, 2018 at 7:24pm
Set imgCmp.IsInteractive = true; and it should raise the event.
VM
Reply #2 - Nov 7th, 2018 at 7:37pm
