Normal Topic Is there a way to automatically space out the links on a node? (Read 2164 times)
twojtylak
Jan 10th, 2019 at 5:08pm
Title says it all. I have nodes with multiple links coming in and going out of each one and I am wondering if there's a way to automatically space them out so the links aren't all going into the middle of the node?
Re: Is there a way to automatically space out the links on a node?
Reply #1 - Jan 11th, 2019 at 6:28am
There's no direct API for this outside of layout classes. You could distribute links with some custom code as below, e.g. call the distributeLinks function from linkCreated event handler, or for each node after building your graph / tree dynamically:
function distributeLinks(node)
	var rect = node.getBounds();
	var bottomLinks = collectLinks(node,
		p => Math.abs(p.y - rect.bottom()) < 1);
	distributeX(node, bottomLinks);
function distributeX(node, links)
	var nl = links.length;
	if (nl == 0)
		return;
	links.sort((l1, l2) =>
		otherEnd(l1, node).getCenter().x - otherEnd(l2, node).getCenter().x);
	var dx = rect.width / (nl + 1);
	var x = rect.left() + dx;
	for (var link of links)
		if (link.getOrigin() == node)
			var p = link.getStartPoint();
			p.x = x;
			link.setStartPoint(p);
		else
			var p = link.getEndPoint();
			p.x = x;
			link.setEndPoint(p);
		x += dx;
		link.updateFromPoints();
function collectLinks(node, predicate)
	var links = [];
	for (var link of node.getOutgoingLinks())
		if (predicate(link.getStartPoint()))
			links.push(link);
	for (var link of node.getIncomingLinks())
		if (predicate(link.getEndPoint()))
			links.push(link);
	return links;
function otherEnd(link, node)
		return link.getDestination();
	else
		return link.getOrigin();
You can add similar handlers for top / left / right sides.
twojtylak
Reply #2 - Jan 11th, 2019 at 4:47pm
You, my friend, are a godsend! I love this library and you are making it so much easier for me to utilize!
