Normal Topic FPS v2.0.50727 On win10 (Read 2978 times)
Guy
Mar 3rd, 2019 at 3:57pm
I'm using the FPS v2.0.50727 on win7 All works fine.
When i'm using WIN10 and using the win10 touch screen driver.
I noticed an issue, as followed:
Clicking on the Virtual keyboard is giving a value only from the second click on the FPS keyboard.
the first touch showing the win10 visual effect as rounding circle without triggering the key itslef, and only the second touch on the same key is working completely by retriving the letter\char of that key.
Somehow the first touch isn't actually a click that retrieve key value. but using mouse click the first click on the virtual keyboard working as the other clicks.
Do you have a clue what is the technical difference ?
If there is a way to solve the first touch to be worked correctly?
Guy
Re: FPS v2.0.50727 On win10
Reply #1 - Mar 4th, 2019 at 9:45am
We do not keep original FPS versions of the control to try this. Check if the problem happens with Mindfusion's version here -
https://mindfusion.eu/KeyboardWpf.zip
We could not reproduce that with a quick test on Win10 running the "Standalone keyboard" sample project.
« Last Edit: Mar 6th, 2019 at 2:40pm by Slavcho »
