Normal Topic Data Context after shift key is released (Read 3198 times)
MisteryGuy_07
Apr 8th, 2019 at 9:46pm
I'm experiencing a problem where all my bindings recalculate after shift key is released automatically even if I set my bindings as OneTime. If I release the shift key manually no extra binding happens. So, is there a reason for that behaviour or I'm into a bug?
I'm trying to optimize my application reducing the number of binding scenarios but this always happens and freezes the whole UI when it happens :/
MisteryGuy_07
Re: Data Context after shift key is released
Reply #1 - Apr 8th, 2019 at 10:34pm
Also, it is possible to change the state of the shift lock on code behind? Thank you
MisteryGuy_07
Reply #2 - Apr 9th, 2019 at 5:33pm
There is a lag after releasing the shift key that is not present when releasing the shift key manually.
Online
Reply #3 - Apr 9th, 2019 at 7:07pm
Try calling keyboard.SendKey(Key.Shift); What kind of bindings do you mean?
