Hot Topic (More than 10 Replies) edited form of diagram (Read 11364 times)
liza
May 14th, 2019 at 6:53am
How can I regenerate my diagram in edited form and after updating it it shold save in database, and load from the database.
AIM
Lyubo
MindFusion team
Re: edited form of diagram
Reply #1 - May 14th, 2019 at 7:54am
Did you check the Network sample as suggested in another thread? It shows exactly how to save/load the diagram from file/JSON.
Lyubo
liza
Reply #2 - May 14th, 2019 at 8:18am
Hey Lyubo,
I am loading data from database using Json. I need to load diagram in the edited form.So that I can edit it and save.
AIM
Lyubo
MindFusion team
Reply #3 - May 14th, 2019 at 10:02am
That's exactly what the Network sample shows - you can load data form JSON or XML, edit the diagram in the browser, than save the edited data again.
liza
Reply #4 - May 14th, 2019 at 11:00am
Please share once again the code.
also used diagram.setAllowInplaceEdit(true); but with this I am not able to get the node text in createnodeevent so I am not able to saving it to database.
AIM
Lyubo
MindFusion team
Reply #5 - May 14th, 2019 at 11:31am
Which code do you need? The Network sample application can be found in the installed location of the MvcDiagram Package - we provide MVC4 and MVC5 examples for both C# and VB.NET.
When using AllowInplaceEdit and you want to detect changes made by the user, you can either handle the NodeTextEditedScript event on the server-side, or the client-side equivalent: leaveInplaceEditMode.
Lyubo
liza
Reply #6 - May 15th, 2019 at 4:15am
When I set  AllowInplaceEdit to true, I can edit the loaded diagram from database but not able to fire any of the event on editing its text etc... and also getting error  diagram_lic.txt not found.
AIM
Lyubo
MindFusion team
Reply #7 - May 15th, 2019 at 5:35am
InplaceEdit events work correctly in my test. Working with the Network sample, I've only added this to the controller's Index method:
view.AllowInplaceEdit = true;
view.NodeTextEditedScript("onNodeTextEdited");
and the following in Index.cshtml:
function onNodeTextEdited(sender, args) {
    alert(args.getNewText());
An alert with the new text will show every time a node text is edited.
Are you getting the 404 error in a MVC application with the scripts and assemblies provided with the MvcDiagram package?
Lyubo
liza
Reply #8 - May 15th, 2019 at 5:59am
Lyubo wrote on May 15th, 2019 at 5:35am:
Lyubo
This is my js code
diagram = Diagram.create($("#testid")[0]);
now when I edited the node no any event is fired and in console getting the following error: Failed to load resource: the server responded with a status of 404 (Not Found)
:64125/FlowChart/diagram_lic.txt:1
AIM
Lyubo
MindFusion team
Reply #9 - May 15th, 2019 at 6:02am
Are you using MVC and MvcDiagram or do you use the standalone JavaScript Diagramming package? The code example above is meant to work in a MVC application, where the DiagramView is created server-side, and you don't create a diagram on the client-side.
liza
Reply #10 - May 15th, 2019 at 6:40am
Hi, No I am using Mindfusion Diagramming for MVC. Created diagram from client side.
AIM
liza
Reply #11 - May 15th, 2019 at 6:41am
It worked for me thanks. Can you please tell me how to get the id of the node in the same method?
liza wrote on May 15th, 2019 at 5:59am:
[quote author=57626E79741B0 link=1557816827/7#7 date=1557898515]Hi,
Lyubo
AIM
liza
Reply #12 - May 15th, 2019 at 6:46am
It worked for me, can You please let me know how can I get id of edited node? I tried args.node.id but getting undefined
AIM
Lyubo
MindFusion team
Reply #13 - May 15th, 2019 at 6:59am
Code (Javascript)
args.getNode().getId()
But it will be undefined, as it doesn't have a default value. You need to have set the id yourself.
liza
Reply #14 - May 15th, 2019 at 7:56am
Hi, Please can you tell me how can I resolve the folowing error which I receiving in console now while doing any edition in base canvas (creating node, link..etc)
Failed to load resource: the server responded with a status of 404 (Not Found) for
AIM
