Normal Topic Drag diagram link by name (Read 3497 times)
lexeranddn
May 22nd, 2019 at 12:10pm
Is it possible to drag diagramlink by name?
Re: Drag diagram link by name
Reply #1 - May 22nd, 2019 at 1:35pm
Do you mean by grabbing its Text or LinkLabels? And then what would you expect  the drag operation to do?
lexeranddn
Reply #2 - May 22nd, 2019 at 1:54pm
Slavcho wrote on May 22nd, 2019 at 1:35pm:
By Text, drag operation.
Reply #3 - May 23rd, 2019 at 8:39am
Changing text's position by dragging it is not supported if that's what you mean. Try using a ShapeNode attached to the DiagramLink (with AttachTo method) to achieve that. Set Transparent property of such nodes to hide their geometry and leave only their Text visible.
lexeranddn
Reply #4 - May 23rd, 2019 at 10:02am
Slavcho wrote on May 23rd, 2019 at 8:39am:
Thanks Slavcho, but I mean dragging diagramLink by its Text, not only dragging Text itself.
Reply #5 - May 23rd, 2019 at 1:32pm
But what should the drag operation do? Like move the whole link, the segment where text is located, or nearest control point?
lexeranddn
Reply #6 - May 23rd, 2019 at 2:32pm
Slavcho wrote on May 23rd, 2019 at 1:32pm:
The whole link.
Regards
Reply #7 - May 24th, 2019 at 7:44am
You can find code for moving the whole link here -
https://mindfusion.eu/Forum/YaBB.pl?num=1548142738/1#1
I can't see any public API to detect where link.Text is located. If you use a LinkLabel instance instead of Text, you could then call LinkLabel.GetEditRect to find the label's position. Other than that, maybe use WPF's VisualTreeHelper to find if there's a GlyphRunDrawing near the mouse position.
lexeranddn
Reply #8 - May 27th, 2019 at 1:14pm
Slavcho wrote on May 24th, 2019 at 7:44am:
Thanks, Slavcho!
