Normal Topic Set width and height of node warp_content - Text size automatically change - Text color (Read 2839 times)
Ngo Duc Quang
Jun 11th, 2019 at 1:44am
- I want to set height and width of node warp_content.
Example: text in the node is long or short, nodes must also have the same width and height.
- Text size automatically change when the nodes resize?
- How to set text color in node and link?
Thanks for helps  Cry Cry
« Last Edit: Jun 11th, 2019 at 2:55am by Ngo Duc Quang »
Online
Re: Set width and height of node warp_content - Text size automatically change - Text color
Reply #1 - Jun 11th, 2019 at 6:55am
You can set your fixed node size by calling node.setBounds(RectF). Text in ShapeNodes should automatically wrap to new lines if it doesn't fit on one. If you want to resize nodes to fit their text tightly, call the resizeToFitText method.
It's not supported out of the box, you might try changing font size from nodeModified event handler depending on how much the node has been resized.
Call DiagramItem.setTextBrush(...) method.
Ngo Duc Quang
Reply #2 - Jun 11th, 2019 at 8:45am
Thank you  Grin This information is very good  Grin
