Normal Topic Non resizable diagram alignment grid during zoom in/out ! (Read 1222 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Jun 25th, 2019 at 5:22am
We show the diagram background alignment grid like this,
this.diagram.setShowGrid(true);
But when zoom in/out, the background grid size also gets changed. Is there any way to stop this?
Kannan
Lyubo
MindFusion team
Re: Non resizable diagram alignment grid during zoom in/out !
Reply #1 - Jun 25th, 2019 at 8:09am
The background grid measures distances in diagram units, that's why it scales, when the view is zoomed. To achieve something close to your requirement, you can adjust the gridSizeX and gridSizeY values in response to a zoom event:
Code (Javascript)
diagram.setVirtualScroll(true); // required for better performance
var defaultGridSize = 4; // this is the default diagram gridSizeX/Y value, can set to other initial value.
diagram.addEventListener("zoomChanged", function (sender, args)
    var scale = diagram.getZoomFactor() / 100;
    diagram.setGridSizeX(defaultGridSize / scale);
    diagram.setGridSizeY(defaultGridSize / scale);
Alternatively, you can consider setting a background image, representing a static grid.
Lyubo
