Hot Topic (More than 10 Replies) Undo & Redo ! (Read 8295 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Re: Undo & Redo !
Reply #15 - Aug 27th, 2020 at 11:04am
We have a align behavior in our diagram. We align all the selected elements in the diagram on click of a button using the below code. The diagram elements are getting aligned but nothing is added to undoManager.undoHistory. May I know how to solve this issue?
  private alignLeft() {
    var itemsToBeAligned = this.diagram.getNodes().filter(x => x.getSelected() === true);
    if (this.selectedNode) {
      var left = this.selectedNode.getBounds().left();
      itemsToBeAligned.forEach(f => {
        if (f != this.selectedNode) {
          let bounds: Rect = f.getBounds();
          var x = left;
          var y = bounds.y;
          f.setBounds(new Rect(x, y, bounds.width, bounds.height), true);
      this.updateLinks(itemsToBeAligned);
Kannan
Re: Undo & Redo !
Reply #16 - Aug 27th, 2020 at 1:35pm
Try this -
diagram.startCompositeOperation();
for (var i = 0, l = diagram.items.length; i < l; i++)
    var command = new ChangeItemCommand(diagram, diagram.items[i]);
    diagram.executeCommand(command);
// align items here
diagram.commitCompositeOperation();
Kannan Thirumal
Senior Member
Re: Undo & Redo !
Reply #17 - Sep 4th, 2020 at 4:17am
This works as desired. Thank you Slavcho  Smiley
