Normal Topic How to create custom layout? (Read 1879 times)
Ankur shah
Sep 5th, 2019 at 6:48am
Can you please let me know what is correct way to build custom layout in mindfusion?
So that we can handle resizeToFitText() and arrange animated function on my custom layout.
Re: How to create custom layout?
Reply #1 - Sep 5th, 2019 at 6:58am
You could set node.Bounds and link.ControlPoints values if all you need is custom positions.
If you want to integrate it with diagram's arrange method, e.g. for handling unconnected subgraphs or animations, you will need to implement MyLayout.prototype.arrange = function (graph) method, that works with Graph, Vertex and Edge objects from MindFusion.Graphs namespace. E.g. see FractalLayout.js if you have the source code, or otherwise our developer could post a sample layout class for some simple tabular arrangement.
Ankur shah
Reply #2 - Sep 5th, 2019 at 7:54am
We don't have source code for mindfusion library. Can you please send me some example?
Lyubo
MindFusion team
Reply #3 - Sep 5th, 2019 at 12:11pm
Below is a simple custom layout that just orders the nodes in a diagram in a grid-like pattern:
Code (Javascript)
var MyLayout = function ()
	this.multipleGraphsPlacement = MindFusion.Graphs.MultipleGraphsPlacement.Horizontal;
	this.margins = 5; // margins from the top left
	this.cols = 5; // nodes per row
	// grid sizes
	this.offsetX = 40;
	this.offsetY = 40;
	var x = 0, y = 0;
	for (var i = 0, col = 1; i < graph.vertices.length; i++, ++col)
		var node = graph.vertices[i];
		node.x = x + node.width / 2;
		node.y = y + node.height / 2;
		x += this.offsetX;
		if (col >= this.cols)
			col = 0;
			x = 0;
			y += this.offsetY;
To use it, just pass a new instance to the arrange method of the diagram:
Code (Javascript)
function arrangeCustom()
    var layout = new MyLayout();
    diagram.arrange(layout);
Lyubo
MindFusion
« Last Edit: Sep 5th, 2019 at 1:23pm by Lyubo »
