Normal Topic Pan movement (Read 1460 times)
liza
Pan movement
Sep 10th, 2019 at 6:37am
I want to give pan movement in diagram, so if the diagram is not showing completely, user can make a drag and get the content in visible window. How I can achieve this. Please help
AIM
liza
Re: Pan movement
Reply #1 - Sep 10th, 2019 at 8:00am
I tried using diagView.Behavior = Behavior.Pan;
But in this it is showing me pan icon and effect is not working also it stopped creating node whihc can be created using mouse.
AIM
Re: Pan movement
Reply #2 - Sep 10th, 2019 at 9:15am
Panning will work only if diagram.Bounds is large enough to allow for scrolling. Obviously it cannot both draw a node and pan while keeping fixed diagram point at mouse position; if you have some criteria to decide whether it should either move or pan at a specific diagram location, you could switch the Behavior value from mouse move event handler.
