Very Hot Topic (More than 25 Replies) Node Edit Mode through F2 ! (Read 20014 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Sep 20th, 2019 at 4:31am
     By double clicking the node, the node can be made as editable. Similarly how to go to edit mode by pressing key F2 key?
Kannan
Lyubo
MindFusion team
Re: Node Edit Mode through F2 !
Reply #1 - Sep 20th, 2019 at 5:40am
This works in my test:
Code (Javascript)
document.onkeydown = function (e)
    var diagram = Diagram.find('diagram');
    if (e.keyCode == 113)
        if (diagram.getActiveItem())
            var item = diagram.getActiveItem();
            diagram.beginEdit(item);
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #2 - Sep 20th, 2019 at 6:36am
Thank you Lyubo. It works fine !  Smiley
My diagram code is expecting a Point object for beginEdit. I gave just 0,0, it still works.
diagram.beginEdit(item, new Point(0, 0));
But if I give 50, 0 also there is no difference.
Kannan Thirumal
Senior Member
Reply #3 - Oct 3rd, 2019 at 1:57pm
I want to edit the shape node when I double click the node. I'm able to do this by the following code,
this.diagram.setAllowInplaceEdit(true);
But I don't want to do for composite node. For that I tried the below code,
    this.diagram.addEventListener(Event.enterInplaceEditMode, (sender, args) => {
      var element = args;
      if (diagram.getActiveItem()) {
        // TODO: Active item is wrongly coming as ShapeNode after clicking ShapeNode and then double clicking CompositeNode?
        //if (item instanceof CompositeNode) {
        if (!(item instanceof ShapeNode)) {
          diagram.endEdit(false);
But the active item is wrongly coming as ShapeNode (which is having text and editable) after clicking ShapeNode and then double clicking CompositeNode?
May I know why this happens?
Kannan
Lyubo
MindFusion team
Reply #4 - Oct 4th, 2019 at 5:46am
ActiveItem is not guaranteed to be correct during the time this event is handled - although in my test using your sample application provided earlier, the above code works for CompositeNode too.
You should use the InplaceEditEventArgs object passed as argument to the handler method to get the item, source of the event. Calling args.getItem() from the handler gets a reference to the correct node in my test.
Lyubo
Kannan Thirumal
Senior Member
Reply #5 - Oct 4th, 2019 at 9:15am
Thank you Lyubo.
I tried the below and it works,
var element = args.getItem();
But when I compare with CompositeNode like this, it returns false,
if (element instanceof CompositeNode) {
May I know why?
Lyubo
MindFusion team
Reply #6 - Oct 4th, 2019 at 9:49am
Use the following instead:
if(MindFusion.AbstractionLayer.isInstanceOfType(MindFusion.Diagramming.CompositeNode, element)) {
Lyubo
Kannan Thirumal
Senior Member
Reply #7 - Oct 4th, 2019 at 12:48pm
This works. Thank you !  Smiley
Kannan Thirumal
Senior Member
Reply #8 - Oct 25th, 2019 at 4:17am
May I know how to set the max length of the edit text box (in shape node)?
For example I want to set the max length of the edit text box to 500 so that the user cannot enter more than 500 characters.
Kannan
Reply #9 - Oct 25th, 2019 at 5:37am
You can set maxLength on the textarea used for editing -
diagram.addEventListener(Events.enterInplaceEditMode, function (sender, args)
	args.getControl().maxLength = 33;
Kannan Thirumal
Senior Member
Reply #10 - Oct 30th, 2019 at 2:29pm
Thanks. It works.
After entering more line of text, the node's height is not changed. I want to adjust the nodes height so that all the text is visible after entering multiple line of text. May I know how to find the height?
I tried like this but height is not coming correctly,
    this.diagram.addEventListener(Event.leaveInplaceEditMode, (sender, args) => {
      var textarea = args.getControl();
      var node = args.getItem();
      node.bounds.height = textarea.scrollHeight;
Kannan
Reply #11 - Oct 30th, 2019 at 5:57pm
Try calling the node's resizeToFitText method with KeepWidth as argument.
Kannan Thirumal
Senior Member
Reply #12 - Oct 31st, 2019 at 5:24am
I tried the same way like below and it works.
      var node = args.getItem() as ShapeNode;
      node.resizeToFitText(MIND.FitSize.KeepWidth);
But after leaving the edit mode, it is not resizing. It is resizing on the second time. That is once again I've go to edit mode and click outside.
Kannan
Reply #13 - Oct 31st, 2019 at 7:01am
Call it from nodeTextEdited handler.
Kannan Thirumal
Senior Member
Reply #14 - Oct 31st, 2019 at 7:24am
Yes this works, Thank you  Smiley
