Page Index Toggle Pages: 1 [2] 3  Send TopicPrint
Very Hot Topic (More than 25 Replies) Node Edit Mode through F2 ! (Read 20066 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Re: Node Edit Mode through F2 !
Reply #15 - Nov 12th, 2019 at 5:29am
Is there any way to cancel the edit? ie after nodeTextEdited, based on some validation, I need to retain the previous text value.
Kannan
Reply #16 - Nov 12th, 2019 at 8:56am
You could restore it from eventArgs.getOldText(); Alternatively you could replace the DiagramItem.prototype.setEditedText(newText) method and call the original only if your validation logic accepts the new text.
Kannan Thirumal
Senior Member
Reply #17 - Nov 15th, 2019 at 8:25am
When the node enters the edit mode, I need to select all the text. I tried like this. Is this the right way?
diagram.addEventListener(Events.enterInplaceEditMode, function (sender, args)
        var control = args.getControl();
        control.selectionStart = 0;
        control.selectionEnd = control.textLength;
Kannan
Reply #18 - Nov 15th, 2019 at 11:05am
You could as well call textarea's select() method -
https://developer.mozilla.org/en-US/docs/Web/API/HTMLInputElement/select
Kannan Thirumal
Senior Member
Reply #19 - Nov 15th, 2019 at 11:16am
It works, Thank you  Smiley
Kannan Thirumal
Senior Member
Reply #20 - Nov 15th, 2019 at 12:48pm
I've set font to the node like below,
node.setFont(new Font("Arial", 12));
I tried the same for the textarea, but didn't work. May I know how to do this?
        //control.setFont(new Font("Arial", 12));
        control.style.fontFamily = "Arial"
        control.style.fontSize = 12
Kannan
Reply #21 - Nov 18th, 2019 at 11:00am
You must specify the unit for CSS assignments to work -
control.style.fontSize = "24pt";
Kannan Thirumal
Senior Member
Reply #22 - Dec 11th, 2019 at 1:07pm
This works fine. But instead of subscribing to document, is it possible to subscribe key down event like this,
    this.canvas.nativeElement.addEventListener("keydown", (args) => {
      this.handleKeyDown(args);
Kannan
Lyubo wrote on Sep 20th, 2019 at 5:40am:
This works in my test:
Code (Javascript)
document.onkeydown = function (e)
    var diagram = Diagram.find('diagram');
    if (e.keyCode == 113)
        if (diagram.getActiveItem())
            var item = diagram.getActiveItem();
            diagram.beginEdit(item);
Lyubo
MindFusion
Lyubo
MindFusion team
Reply #23 - Dec 12th, 2019 at 11:15am
Is there any particular reason why you want to add your handler to the canvas element as opposed to document/window? The canvas DOM element is not designed to listen for keyboard input, so subscribing to a keydown event won't work out of the box.
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #24 - Dec 12th, 2019 at 1:36pm
     In my application, I've two component, one left side and other right side. One has canvas and another has tree view. I want to edit canvas node when it is selected and want to edit tree node when it is selected. I added document.onkeydown on both the component. So when F2 is pressed, both the code is called. Want to avoid this.
Kannan
Lyubo
MindFusion team
Reply #25 - Dec 12th, 2019 at 1:40pm
In addition to the above, if you want to receive the keydown events only when the diagram has focus, you can add your handler to the div overlay the diagram component creates. You can obtain a reference to it via id - it's id represents the diagram's canvas ID with "_focusable" appended to it, or via the diagram.focusDiv reference. Or you can check for the source element in your global document.keydown event handler.
Code (Javascript)
var diagramFocusDiv = document.getElementById("diagram_focusable"); // canvas.id + _focusable
// or
// var diagramFocusDiv  = diagram.focusDiv as any; // if using TypeScript, as it's an internal field.
diagramFocusDiv.addEventListener("keydown", myKeyDownHandler);
Lyubo
Kannan Thirumal
Senior Member
Reply #26 - Apr 23rd, 2020 at 1:52pm
This works fine when the diagram is opened in one tab. In my application, I've added the canvas in a component and loading the component in more than one tab. In that case, this event is raised for only the canvas in the last tab. May I know how to fix this issue? I tried the below methods,
// This is not called for any canvas
var diagramFocusDiv = (this.diagram as any).focusDiv as any;
diagramFocusDiv.addEventListener("keydown", (args) => {
// This is called for only one canvas (the lastly opened)
    document.onkeydown = (e) => {
      // This also not works properly
Kannan
« Last Edit: Apr 23rd, 2020 at 2:56pm by Kannan Thirumal »
Kannan Thirumal
Senior Member
Reply #27 - Apr 24th, 2020 at 4:59am
Also I tried by adding a div element around the canvas like this,
        <div #canvasDivElement
           (click)="onCanvasDivClicked($event)"
           (keydown)="onCanvasDivKeydown($event)">
          <canvas #canvas id="diagram" draggable="true"></canvas>
        </div>
  public onCanvasDivClicked(e: MouseEvent): void {
    var args = e;
  public onCanvasDivKeydown(e: KeyboardEvent): void {
    this.handleKeyDown(e);
    this.canvasDivElement.nativeElement.addEventListener("keydown", (args) => {
      this.handleKeyDown(args); // Not called . . .
Here onCanvasDivClicked is called but onCanvasDivKeydown is not called.
Kannan
Kannan Thirumal wrote on Apr 23rd, 2020 at 1:52pm:
Kannan
Lyubo
MindFusion team
Reply #28 - Apr 24th, 2020 at 5:50am
Did you try listening for the keydown event on the diagram's focus div as it's shown in a previous post above? In order for the div to receive key events, it must be focusable and this is achieved by setting a tabindex. Diagram's focus div is already focusable, so you could use that without adding additional elements to your DOM tree. If you have more than one diagram instance, you can identify the different focusable divs by their ids.
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #29 - Apr 24th, 2020 at 7:29am
Hi Lyubo,
I already tried that. It is coming for one tab not for other tabs.
I too have the below code,
    this.diagram.addEventListener(Event.nodeClicked, (sender, args) => {
      this.handleNodeClicked(args);
    this.diagram.addEventListener(Event.nodeDeleting, (sender, args: NodeEventArgs) => {
      this.handleNodeDeleting(args);
nodeClicked is raised for diagram in both the tabs but nodeDeleting is raised only for the new tab.
Kannan
