Normal Topic Use of Dispose on Diagram and DiagramView (Read 1960 times)
David Long
Dec 4th, 2019 at 1:10pm
When closing a Windows Form is there a best practice for disposing of the Diagram and DiagramView instances?  Do I have to explicitly do this?  When opening and closing a large number of files and creating these objects I start to get low on memory, so it seems I'm not disposing of something correctly!
Any help gratefully received.
David
Re: Use of Dispose on Diagram and DiagramView
Reply #1 - Dec 5th, 2019 at 6:48am
Check if there aren't some variables left in the application pointing to DiagramView, Diagram or any nodes/links. You should be able to find what prevents GC from disposing of objects using VS Diagnostic Tools -> Memory Usage -> Take Snapshot. Call that after closing your form, click View Heap and find if there's any DiagramView instance left. Select it and check the 'Paths to Root' pane - items showing [Cycle Detected] are safe, while ones leading to variables in parent form or some static references need to be cleared.
David Long
Reply #2 - Dec 5th, 2019 at 4:09pm
Thanks for your help. It seems that I am hanging on to a reference to the whole Form that contains the DiagramView. The 'Paths to root' pane does not seem too helpful, so I might try a different memory diagnostic tool or revisit the problem another day!
Thanks again
David
Edit: 'Paths to root' was actually useful, I just didn't know what I was looking at! The problem is the many event handlers that have a reference to the form - apparently a know problem.  Sad
« Last Edit: Dec 5th, 2019 at 8:43pm by David Long »
