Normal Topic Some artifacts when clicking on diagram (Read 1515 times)
Anna Malashkina
Dec 6th, 2019 at 1:48pm
Hi all,
I set diagram behavior as "do nothing":
diagram.setBehavior(MindFusion.Diagramming.Behavior.DoNothing);
But I still have node selected (ports became visible) when I click on it. Also I have some strange  artifacts (see example attached), it looks like some selected nodes a duplicated with an offset. Is it possible to turn it off?
Online
Re: Some artifacts when clicking on diagram
Reply #1 - Dec 10th, 2019 at 8:34am
Hi Anna,
Try this -
var originalOnClick = Diagram.prototype.onClick;
Diagram.prototype.onClick = function (position, button)
	if (this.getBehavior() == Behavior.DoNothing)
		var clickedItem = this.getItemAt(position, true);
		this.raiseClicked(clickedItem, position, button);
	else
		originalOnClick.apply(this, [position, button]);
This could be the shadow effect, or otherwise the control might not have repainted correctly after some modification of yours (e.g. if you assign to bounds field directly instead of calling setBounds, or a property setter of ours omits invalidating); try calling diagram.invalidate() to do a full repaint.
