Normal Topic How to allow font fallback in ContainerNodes that have a parent Diagram (Read 2066 times)
Randall S
Jan 1st, 2020 at 6:05pm
Hi all, happy New Year.
I am having trouble with some behavior in ContainerNodes that seems a bit odd.
If you take the Anchors.zip official example project (the forum prevents me from providing a link, but if you Google "mindfusion anchors sample" it should be the first result).
And you delete all the code in the Form1_Load() function and replace it with this:
private void Form1_Load(object sender, EventArgs e)
            var container = new ContainerNode();
            container.Font = new Font("Segoe UI", 10);
            container.Caption = "テスト";
            container.Bounds = new RectangleF(0, 0, 20, 20);
            diagram.Nodes.Add(container);
This looks fine when you run it (see attachment: 1.png). Even though "Segoe UI" font doesn't support Japanese characters, the renderer apparently falls back to some other font and displays the text, as is common for WinForms controls.
However if I pass in a Diagram to the ToolContainer constructor, it seems that this breaks the fallback behavior, and the text is rendered as boxes (see attachment: 2.png). That code is like this:
            var container = new ContainerNode(new Diagram());
I have to explicitly set a Japanese font, like MS Gothic, instead of Segoe UI, for the text to render correctly (on the 4th line there).
So my question is, how can I give the ToolContainer a parent Diagram while still maintaining font fallback ability?
Thanks in advance.
Re: How to allow font fallback in ContainerNodes that have a parent Diagram
Reply #1 - Jan 2nd, 2020 at 4:55am
Hi and happy 2020,
There is the NoFontFallback flag in TextFormat.FormatFlags which the second constructor overload probably copies from the diagram. Try disabling the flag either in diagram's or container's instance.
Randall S
Reply #2 - Jan 2nd, 2020 at 6:22pm
Thanks Slavcho, happy 2020 to you too.
You are right, I am able to enable font fallback by modifying the TextFormat.FormatFlags like you suggested. It looks like Diagram has TextFormat.FormatFlags == StringFormatFlags.NoFontFallback by default.
For anyone else reading, the solution looks like this:
diagram.TextFormat.FormatFlags &= ~StringFormatFlags.NoFontFallback;
var container = new ContainerNode(diagram);
Randall
