Normal Topic How to refresh tableNode after create? (Read 1639 times)
Brarord
Jan 3rd, 2020 at 7:36am
is there any way to refresh table after create? If you wanna ask why i want to do this, then this is the reason:
1. This is my tableNode immediately after creation
I didn't touch its position x y. As you can see the scroll bar hasn't refreshed its position yet.
Now, if I tried to move the table by even a millimeter, then immediately the position of the scroll bar will be updated and there will be no problem with that anymore.
2.
3.
This problem came after i change caption height for my tableNodes with this method:
table.setCaptionHeight(7.5);
Is there any way to fix this? Maybe like i said before some refresh method which is used by this "positioning algorithm".
Regards
poor student  Undecided
Re: How to refresh tableNode after create?
Reply #1 - Jan 3rd, 2020 at 10:48am
Try calling table.onUpdateBounds() after setCaptionHeight().
Brarord
Reply #2 - Jan 3rd, 2020 at 8:09pm
I tried that ways:
1. tableNode.onUpdateBounds(true);
2. tableNode.onUpdateBounds();
The method has no effect.
I did some research about this, and i find this:
https://mindfusion.org/onlinehelp/jdiagram/M_com_mindfusion_diagramming_FreeForm...
Are you sure I can use this method when i am using TableNode Class, it seems it is in diffrent class? I am not sure.
I did not find this method in TableNode documentation, but i find it with debugger. This method is in "__proto__":
Brarord
Reply #3 - Jan 3rd, 2020 at 11:07pm
Okay i already fix that with that method:
tableNode.scroller.updateLocation();
