Normal Topic ShapeNode Null reference when specifying both OutlineFormula and Text Area (Read 1979 times)
rdwheeler
Feb 3rd, 2020 at 6:33pm
In Diagramming.WinForms 6.6, I am encountering a null ref error (attached) when I specify both OutlineFormula and TextArea properties of ShapeNode.
                 _baseLabelArea = new ElementTemplate[]
                       new LineTemplate(10, 10, 90, 10),
                       new LineTemplate(90, 10, 90, 90),
                       new LineTemplate(90, 90, 10, 90),
                       new LineTemplate(10, 90, 10, 10)
                 string script = $@"
                       apOffset = {PART_ATTACH_POINT_OFFSET};
                       apDepth = {PART_ATTACH_POINT_DEPTH};
                       bump = 2;
                       apLong = (Height) - (apOffset * 2);
                       vapOffset = apLong + (apOffset * 2);
                       MoveTo(apOffset, 0);
                       ArcTo(0, apOffset - bump, false, true, apOffset, apOffset);
                       LineTo(0, apOffset);
                       LineTo(1, apOffset);
                       LineTo(apDepth + 1, Height / 2);
                       LineTo(1, Height - apOffset);
                       LineTo(0, Height - apOffset);
                       LineTo(0, Height - apOffset + bump);
                       ArcTo(apOffset, Height, false, true, apOffset, apOffset);
                       LineTo(Width - vapOffset, Height);
                       LineTo(Width - vapOffset + (apLong / 2), Height + apDepth);
                       LineTo(Width - vapOffset + apLong, Height);
                       LineTo(Width - apOffset, Height);
                       ArcTo(Width, Height - apOffset, false, true, apOffset, apOffset);
                       LineTo(Width + apDepth, Height / 2);
                       LineTo(Width, apOffset);
                       ArcTo(Width - apOffset, 0, false, true, apOffset, apOffset);
                       LineTo(apOffset, 0);";
                 _baseShape = new Shape(script, "Part");
                 _baseShape.TextArea = _baseLabelArea;
If I do not specify TextArea I see no error, or if I use a ElementTemplate instead of OutlineFormula, I see no error.
NullRef.txt (Attachment deleted)
Re: ShapeNode Null reference when specifying both OutlineFormula and Text Area
Reply #1 - Feb 4th, 2020 at 10:48am
Add some empty arrays for the other ElementTemplate[] properties and it will work -
 _baseShape.Outline = new ElementTemplate[] {};
 _baseShape.Decorations = new ElementTemplate[] {};
The formula is still evaluated with higher priority than the arrays. We'll add null checks for next release.
rdwheeler
Reply #2 - Feb 11th, 2020 at 9:53pm
This works. Thanks!
