Normal Topic How to update Diagram node text in client side timer using js (Read 6971 times)
girikul
Feb 25th, 2020 at 5:43am
I am using Diagram control as shown below
<asp:UpdatePanel ID="UpdatePanel1" runat="server" UpdateMode="Conditional">
        <ContentTemplate>
        <ndiag:DiagramView runat="server" ID="diagramView" ClientSideMode="Canvas" Width="1900px" Height="1050px" NodeDoubleClickedScript="onNodeDoubleClicked" Behavior="DoNothing">
        </ndiag:DiagramView>
    </ContentTemplate>
</asp:UpdatePanel>
We have collection of nodes in the Diagram
Based on some conditions we update the text of the node in the diagram in the server side as
For Each node As DiagramNode In diagramView.Diagram.Nodes
              If node.Tag.ToString.ToUpper = "TEST" Then
CType(node, ShapeNode).Text = myValue
  End If
Next
Now I need to update this node text value in client side which is received by web service. There is timer function
function myTimer() {
        $.ajax({
            url: webServiceURL,
            type: "POST",
            dataType: "xml",
            data: soapRequest,
            processData: false,
            contentType: "text/xml; charset=\"utf-8\"",
            success: OnSuccess,
            error: OnError
function OnSuccess(data, status, req) {
        if (status == "success") {
           //Here I need to put the code to update the node text.
Diagram object methods like Diagram.nodes not available in client side. Could you please provide sample code to achieve this?
Re: How to update Diagram node text in client side timer using js
Reply #1 - Feb 25th, 2020 at 6:02am
In JavaScript that should look like -
for (var node of diagram.getNodes())
    if (node.getTag().toUpperCase() == "TEST")
        node.setText(myValue);
where 'diagram' is a reference to the client-side MindFusion.Diagramming.Diagram instance, which you get by calling $find or Diagram.find with DiagramView.ID as argument.
girikul
Reply #2 - Feb 25th, 2020 at 8:14am
When I try to get nodes using Digram.GetNodes() like below
var Diagram = document.getElementById('<%= diagramView.ClientID%>');
var obj = Diagram.getNodes();
It did not work and I get error as
TypeError: Diagram.getNodes is not a function
Is there mistake in my code?
Also
doesn't compile.
Regards
Reply #3 - Feb 25th, 2020 at 8:30am
getElementById returns the view's DIV element. Call MindFusion.Diagramming.Diagram.find(id) or $find(id) instead to get the JS Diagram model object. E.g. see the OrgBrowser example for modifying diagram on client side from web service results.
girikul
Reply #4 - Feb 25th, 2020 at 8:58am
I tried with both methods as
MindFusion.Diagramming.Diagram.find(id) or $find(id) but still no luck. It is null somehow.
var Diagram = MindFusion.Diagramming.Diagram.find('diagramView');
var diagram1 = $find('diagramView');
This gives me following errors as
Uncaught Sys.ArgumentException: Sys.ArgumentException: MindFusion.Diagramming.Diagram does not derive from Sys.Component.
Parameter name: type
and
Uncaught TypeError: Cannot read property 'getNodes' of null
at Object.OnSuccess [as success]
Reply #5 - Feb 25th, 2020 at 9:31am
If I remember correctly UpdatePanel adds some prefix to DOM element IDs. Try passing '<%= diagramView.ClientID%>' as argument to the find method instead of 'diagramView'.
girikul
Reply #6 - Feb 28th, 2020 at 4:51pm
Hi Slavcho,
Sorry for late reply.
The issue was that, I was using control in .ascx page. It works OK in .aspx page. Thanks a lot for your help.
Reply #7 - Mar 2nd, 2020 at 7:19am
It works from user control too in my test:
user control ascx -
<%@ Control
    Language="C#"
    AutoEventWireup="true"
    CodeBehind="DiagUserCtrl.ascx.cs"
    Inherits="UserCtrlTest.DiagUserCtrl" %>
<%@ Register
    TagPrefix="diag"
    Namespace="MindFusion.Diagramming.WebForms"
    Assembly="MindFusion.Diagramming.WebForms" %>
<diag:DiagramView
    ID="diagView" runat="server"
    ControlLoadedScript="onControlLoaded" />
<script>
function onControlLoaded()
    var id = "<%= diagView.ClientID %>";
    //alert(id);
    var diagram = MindFusion.Diagramming.Diagram.find(id);
    //alert(diagram);
    var node = diagram.getFactory().createShapeNode(10, 10, 40, 40);
    node.setText("hello from user control");
</script>
default aspx -
<%@ Page
    Title="Home Page"
    Language="C#"
    MasterPageFile="~/Site.Master"
    CodeBehind="Default.aspx.cs"
    Inherits="UserCtrlTest._Default" %>
<%@ Register
    Src="~/DiagUserCtrl.ascx"
    TagPrefix="duc"
    TagName="DiagUserCtrl" %>
<asp:Content
    ID="BodyContent"
    ContentPlaceHolderID="MainContent"
    runat="server">
    <duc:DiagUserCtrl ID="test" runat="server" />
</asp:Content>
