Hot Topic (More than 10 Replies) Diagram control and display custom graphics (Read 4654 times)
JackPan
Apr 13th, 2020 at 12:51pm
Hi All,
I want to implement those custom graphs, and then store these graphs. When I use them later, I can click on one of the graphs and generate the graph by dragging and dropping the mouse in the diagram. How to implement these graphs?
I want to sort out ideas. Does the database need to be used?
Any assistance would be appreciated.
Cheers,
Jack
JackPan
Re: Diagram control and display custom graphics
Reply #1 - Apr 21st, 2020 at 9:14am
Hi All,
I want to save the graphics on the corresponding button just like the screenshot 4_14_4.Then click the button R0201 just like the screenshot 4_21_1, then drag the left mouse button in the diagram to produce the corresponding figure.
Cheers,
Jack
JackPan
Reply #2 - Apr 21st, 2020 at 9:15am
Added:
Screenshot 4 _14_4
JackPan
Reply #3 - Apr 22nd, 2020 at 2:38pm
Hello, I have been waiting for your reply. Smiley
Lyubo
MindFusion team
Reply #4 - Apr 23rd, 2020 at 5:18am
You can check out the VisioStencils sample project included in the WpfDiagram package for ideas on how to populate a NodeListView control with custom nodes and handling the OnDrop event when a DragDrop operation occurs. In your case you most likely won't use Visio shapes, so just assigning an Image or a custom shape to the nodes will be enough.
Lyubo
MindFusion
JackPan
Reply #5 - Apr 23rd, 2020 at 6:24am
Thank you, Lyubo.
Smiley Smiley Smiley
I will study the VisioStencils sample project.
I wish you a better and better life.
Cheers,
Jack
JackPan
Reply #6 - May 4th, 2020 at 9:31am
Hi All,
How to achieve several images seamless Mosaic into an image?
Cheers,
Jack
Lyubo
MindFusion team
Reply #7 - May 4th, 2020 at 11:24am
You can check out the TreeMap sample application included in the WpfDiagram package. It shows one way to lay out rectangular nodes. Maybe it'll fit your requirements.
Lyubo
MindFusion
JackPan
Reply #8 - May 4th, 2020 at 1:59pm
Thank you very much. Lyubo. Smiley Smiley Smiley Smiley
JackPan
Reply #9 - May 6th, 2020 at 1:58pm
Hi All,
Because the coordinate value of the image taken by the camera is shifted to cause the phenomenon of approximate background image, I want to correct all the coordinate values ​​of this background image, just like the effect of the image above it: the background image The replaced white dot moves to the purple dot with the correct coordinate value, so they overlap, so that all the coordinate values ​​in the entire background image are corrected to be the same as the image above it.
Cheers,
Jack
Online
Reply #10 - May 7th, 2020 at 1:11pm
This sounds like a computer-vision problem, and has nothing to do with the diagram control. Maybe look into OpenCV library's edge detection algorithms (https://opencv.org/), or check if the code here works for you, I imagine removing empty margin space from both images and drawing them on top of each other with same size will make the dots match -
https://stackoverflow.com/questions/13548962/crop-remove-unwanted-space-at-the-e...
JackPan
Reply #11 - May 7th, 2020 at 1:46pm
Thank you very much Slavcho.
Smiley Smiley Smiley Smiley Smiley
I will carefully read the ideas you provided to me.
Please pay attention to epidemic prevention.I send my best wishes to you and hope you can return to normal life as soon as possible.
