Normal Topic The program runs and the diagram immediately displays ShapeNode (Read 1601 times)
JackPan
Apr 14th, 2020 at 7:28am
Hi All,
I want to display the overlayNode separately as soon as the program is running. The default length and width are (100,100) displayed in the two TextBoxes, the same effect as in the screenshot. Currently overlayNode is created after the imageNode is created.
Any assistance would be appreciated.
Cheers,
JackPan
Lyubo
MindFusion team
Re: The program runs and the diagram immediately displays ShapeNode
Reply #1 - Apr 15th, 2020 at 6:56am
Create your overlayNode before creating your imageNode then, maybe in a Window Loaded handler. I don't see a problem here, it's just basic programming flow.
Lyubo
MindFusion
JackPan
Reply #2 - Apr 15th, 2020 at 7:44am
Yes, you're right. I did it.
Thank you, Lyubo. Smiley
Cheers,
JackPan
