Normal Topic Compatibility issues with changing the Window class to another class. (Read 2022 times)
JackPan
Apr 20th, 2020 at 3:06pm
Hi All,
I have embedded another control in the project and need to change the original window class to DXRibbonWindow: public partial class MainWindow: DXRibbonWindow. This class:DXRibbonWindow also inherits from Windows and other interfaces. The result is that the event diagram_PreviewMouseWheel is not responding. Is there any way to solve it?
Any assistance would be appreciated.
Please pay attention to epidemic prevention.I send my best wishes to you and hope you can return to normal life as soon as possible.
Jack
Lyubo
MindFusion team
Re: Compatibility issues with changing the Window class to another class.
Reply #1 - Apr 21st, 2020 at 6:19am
Make sure your DXRibbonWindow is not already handling the PreviewMouseWheel event and setting it to Handled.
Lyubo
MindFusion
JackPan
Reply #2 - Apr 21st, 2020 at 8:59am
Thank you, Lyubo.
Yes, e.andled I've set true.DXRibbonWindow also does not set the MouseWheel event.The result still affects the diagram_PreviewMouseWheel trigger.
But it doesn't matter. I've decided not to use this control of it, but to go back to the Windows class.Because it will affect my normal use of the diagram.
cheers,
Jack
