Normal Topic Nodelistview tooltip (Read 2369 times)
PeteWhite
May 15th, 2020 at 2:43pm
Hi, is there a way of showing a node's tooltip while it is within the Nodelistview?
I've also noticed that no events are firing, specifically the MouseEnter, MouseMove, and MouseLeave events.
Online
Re: Nodelistview tooltip
Reply #1 - May 18th, 2020 at 6:52am
Try something like this -
var toolTip = new ToolTip();
foreach (Control control in nodeListView.Controls)
	if (control.Name == "list")
		var list = (ListBox)control;
		list.MouseMove += (sender, args) =>
			var idx = list.IndexFromPoint(args.Location);
			if (idx >= 0 && idx < list.Items.Count)
				var dnode = (DraggedNode)list.Items[idx];
				var node = dnode.Node;
				toolTip.Show(node.ToolTip, list,
					args.Location.X + 12, args.Location.Y + 12);
		break;
We'll try to implement built-in tooltips for upcoming release.
PeteWhite
Reply #2 - Jan 20th, 2024 at 4:45pm
PeteWhite wrote on May 15th, 2020 at 2:43pm:
Hi, I know this is an old topic, but the events highlighted above are still not working. Any advice would be appreciated.
Cheers,
Pete
Online
Reply #3 - Jan 22nd, 2024 at 10:00am
Try this build -
https://mindfusion.eu/_temp/nodelist_events.zip
PeteWhite
Reply #4 - Jan 22nd, 2024 at 11:16pm
Thanks, will that work with dotnet8 ?
Cheers,
Pete
Online
Reply #5 - Jan 23rd, 2024 at 6:12am
It should work.
PeteWhite
Reply #6 - Feb 4th, 2024 at 5:04pm
Thanks Slavcho, that's working great now.
Another question... is there a way to define the radius of the corners of the rounded rectangle in the NodeListView? When dragged onto the DiagramView they look ok, but are a bit "sharp" for my liking in the NodeListView.
Cheers,
Pete
Online
Reply #7 - Feb 5th, 2024 at 11:29am
Hi Pete,
Try this build, it now draws the nodes in specified measure unit (millimeter by default) so should look the same as in diagram -
https://mindfusion.eu/_beta/fcnet702.zip
PeteWhite
Reply #8 - Feb 5th, 2024 at 5:20pm
That's brilliant.
Thanks Slavcho, as always, excellent, and speedy customer support Smiley
Cheers,
Pete
