Normal Topic Keydown Event in MVC (Read 2185 times)
Megan1717
May 18th, 2020 at 5:54pm
I need to be able to get the keydown event, such as when the user presses the Delete key, in order to do some business logic. In the Silverlight version of MindFusion, we tapped into the Diagram's KeyDown event property and then attached an event handler to the diagram: diagram.KeyDown += diagram_KeyDown.
In the MVC verision, event handlers appear to be added using various properties available to the DiagramView class, such NodeClickedScript and LinkCreatedScript. We do this successfully in the server side code for several evens. However, there does not appear to be a keydown or keypress property to tap into for the DiagramView, Diagram, or Events classes.
I have tried adding the JS onkeydown event listener to the diagram and to the document on the client side, but this never seems to fire.
How can we tap into the keydown event on the client side for MVC?
Thanks.
Re: Keydown Event in MVC
Reply #1 - May 19th, 2020 at 5:00am
The diagram uses a hidden div to track focus, in order to avoid browsers' auto-scroll behavior when clicked. Try attaching your handler to it -
var diagramFocusDiv = diagram.focusDiv;
diagramFocusDiv.addEventListener(
    "keydown", myKeyDownHandler);
Megan1717
Reply #2 - May 19th, 2020 at 9:18pm
This is perfect. Thanks very much!
