Page Index Toggle Pages: 1 2 [3] 4 5  Send TopicPrint
Very Hot Topic (More than 25 Replies) how to set wpf spreadsheet export pdf font. (Read 29550 times)
Re: how to set wpf spreadsheet export pdf font.
Reply #30 - Jun 4th, 2020 at 11:18am
try emailing it zipped with max. compression to support@mindfusion.eu
David Chiang
Reply #31 - Jun 4th, 2020 at 12:01pm
Just did from lwcxxx@hotmail.com.
Reply #32 - Jun 4th, 2020 at 12:42pm
Better edit out your email address above or it will get spammed. We have received the font file and ours is exactly the same when compared in binary mode, so problem is not font itself. If you attach a test project of yours showing failed export for MingLiU + Unicode we could find something else in program's state leading to problems. Have you tried if using same font as in reports along with Unicode encoding fixes spreadsheet's export?
David Chiang
Reply #33 - Jun 4th, 2020 at 1:10pm
I just send out the project files but without server URL. The program will not run but it is the complete code.
Reply #34 - Jun 7th, 2020 at 11:12am
We think this build should fix export -
https://mindfusion.eu/_temp/pdf_font_name.zip
Problem was MingLiU.ttf also contains native Chinese names of the font (like 細明體) which WPF probably returns first on Chinese versions of Windows. PDF objects need to be encoded in ASCII so exporter would fail if font name is in Chinese on your side, but worked for us since we get 'MingLiU' first. Now it should always encode using Latin name of the font. You'll still need to export using the Unicode option.
David Chiang
Reply #35 - Jun 7th, 2020 at 1:36pm
Thanks a lot, But I still get the same result with following code
                       var activeSheet = workbookView.ActiveWorksheet;
                       PdfExporter pdfExporter = new PdfExporter();
                       //pdfExporter.FontCachePath = @"C:\ZZReport\pdflib-fontrecords.xml";
                       //pdfExporter.AutoDetectEncoding = false;
                       //pdfExporter.DefaultEncoding = Encoding.Unicode;
                       pdfExporter.Export(activeSheet, dialog.FileName);
David Chiang
Reply #36 - Jun 7th, 2020 at 1:41pm
With following code
I recompile the code and use the new library you send me.
Reply #37 - Jun 8th, 2020 at 6:21am
Please attach the PDF file. What does this print on your side if you add MingLiU-TextBlock to window.xaml?
<TextBlock x:Name="test" Text="test" FontFamily="MingLiU" />
void Window_Loaded(object s, RoutedEventArgs e)
	var drawing = VisualTreeHelper.GetDrawing(test);
	foreach (var child in drawing.Children)
		var group = child as DrawingGroup;
		if (group != null)
			foreach (var child2 in group.Children)
				var glyphRun = child2 as GlyphRunDrawing;
				if (glyphRun != null)
					foreach (var kv in glyphRun.GlyphRun.GlyphTypeface.FamilyNames)
						Debug.WriteLine(
							string.Format("{0}:{1}", kv.Key, kv.Value));
David Chiang
Reply #38 - Jun 9th, 2020 at 2:37am
The debug show following
en-US:MingLiU
zh-HK:細明體
zh-TW:細明體
and I add following code in my program
           private void Window_Loaded(object sender, RoutedEventArgs e)
                       if (group != null)
                                               Debug.WriteLine(
Reply #39 - Jun 9th, 2020 at 5:52am
It shouldn't work any different than our Windows version then if reporting en-US variant of font name. Please attach your last PDF file so we can examine the font objects generated. Make sure your project is using new assembly files, e.g. check their modification dates in bin/debug after rebuilding.
David Chiang
Reply #40 - Jun 9th, 2020 at 12:23pm
Here is the result and code are
result.rar (Attachment deleted)
Reply #41 - Jun 9th, 2020 at 12:33pm
This PDF still tries to encode the Chinese font name for MingLiU instead of the English one, so the project's probably still referencing the older assemblies. Have you verified dll file dates inside bin/debug after rebuilding are ones from latest zip file above: 6/7/2020 1:53PM?
David Chiang
Reply #42 - Jun 9th, 2020 at 1:17pm
This is the current version.
Reply #43 - Jun 9th, 2020 at 4:48pm
this build implements logging, please call pdfExporter.EnableLogging("log.txt") and attach the log file -
https://mindfusion.eu/_temp/pdf_log.zip
David Chiang
Reply #44 - Jun 9th, 2020 at 10:10pm
Here is the log file.
log.txt (Attachment deleted)
