Page Index Toggle Pages: [1] 2 3 ... 5 Send TopicPrint
Very Hot Topic (More than 25 Replies) how to set wpf spreadsheet export pdf font. (Read 29804 times)
David Chiang
May 27th, 2020 at 7:26am
Hello, How to set the right font for export to PDF? Meaning different language characters.  Both csv and xlsx are correct. Only happen when export to PDF. Thanks
Re: how to set wpf spreadsheet export pdf font.
Reply #1 - May 27th, 2020 at 12:08pm
If you are getting incorrect PDFs from text containing CJK glyphs, try these settings -
pdfex.AutoDetectEncoding = false;
pdfex.DefaultEncoding = Encoding.Unicode;
David Chiang
Reply #2 - May 27th, 2020 at 12:47pm
Thanks for the reply.
Apply the code like following
                       var activeSheet = workbookView.ActiveWorksheet;
                       PdfExporter pdfExporter = new PdfExporter();
                       pdfExporter.AutoDetectEncoding = false;
                       pdfExporter.DefaultEncoding = Encoding.Unicode;
                       pdfExporter.Export(activeSheet, dialog.FileName);
The original data is like :
OrderID      DSID      warehouse      訂單日期      pv      Total Sales
703012674      700187543      20867      2020/5/14 上午 12:00:00      185      2276
703012676      693739      21300      2020/5/14 上午 12:00:00      120      1596
After apply the code the data is not readable and like
P s e f s J E E T J E x b s f i p v t fYª%V5•6Ç q w U p u b m ! T b m f t
8 1 4 1 2 3 7 8 5 8 1 1 2 9 8 6 5 4 3 1 9 7 8 3 1 3 1 0 6 0 2 5 2 9 6 3 3 8 7
8 1 4 1 2 3 7 8 7 7 : 4 8 4 : 3 2 4 1 1 3 1 3 1 0 6 0 2 5 2 3 1 2 6 : 7
This is data export from PDF export
OrderID DSID warehouse U®eåg pv Total Sales
703012674700187543 20867 2020/5/14 185 2276
703012676 693739 21300 2020/5/14 120 1596
This is the data should shown
Thanks for the help
Reply #3 - May 27th, 2020 at 4:20pm
It seems to export well enough in my test shown in attached screenshot, opening the PDF in Adobe Reader or Chrome. I also had to set cells' Style.FontName to Unicode-enabled font in order to see glyphs in the spreadsheet itself -
var range = sheet.CellRanges[0, 0, 1000, 10000];
range.Style.FontName = "Arial Unicode MS";
The PDF's looking strange in Firefox and Edge though, were you opening your PDF in one of these browsers?
test_002.pdf (Attachment deleted)
David Chiang
Reply #4 - May 28th, 2020 at 12:25am
The text shown on the spreadsheet is correct but it not correct when export to PDF. Other export types are OK (XLSX, CSV). I try to display on Chrome, Edge and PDF reader but failed on all of them.   On the PDF reader, it failed to open the file with error message show on the screen.
David Chiang
Reply #5 - May 28th, 2020 at 12:26am
Open from the acrobatreader
David Chiang
Reply #6 - May 28th, 2020 at 12:26am
Open from the Edge
David Chiang
Reply #7 - May 28th, 2020 at 12:27am
The data itself
David Chiang
Reply #8 - May 28th, 2020 at 12:29am
Here is the code
           private void GenerateRandomFont(ref Cell cell)
                 var style = cell.Style;
                 style.FontName = "MingLiU";
                 style.FontBold = false;
                 style.FontItalic = false;
                 //style.FontSize = 14;
           private void menuItemPdf_Click(object sender, RoutedEventArgs e)
                 SaveFileDialog dialog = new SaveFileDialog();
                 dialog.Filter = "PDF Files (*.pdf)|*.pdf|All files (*.*)|*.*||";
                 if (dialog.ShowDialog(this) == true)
                       //pdfExporter.AutoDetectEncoding = false;
                       //pdfExporter.DefaultEncoding = Encoding.Unicode;
David Chiang
Reply #9 - May 28th, 2020 at 3:06am
zipped  pdf file
ddd.rar (Attachment deleted)
Reply #10 - May 28th, 2020 at 5:24am
What does that message mean in English?
You will need to uncomment these to get PDFs working in Reader / Chrome.
David Chiang
Reply #11 - May 28th, 2020 at 6:01am
meaning "Error processing page 110"
https://community.adobe.com/t5/acrobat-reader/error-processing-page-110/td-p/970
1498?page=1
Unmask the comments and run the data. The same set of data is not correct .
I try to add the font from adobe but no luck and change the PDF library from 1.3.2.400 to 1.3.2.450 still not working
Reply #12 - May 28th, 2020 at 6:08am
It worked for me with only a few strings from your sample data, so I guess something else from all the cells is breaking it. Please attach the spreadsheet file you are exporting and our developer will check.
David Chiang
Reply #13 - May 28th, 2020 at 6:28am
the attach file the data export to xlsx
bbb.xlsx (Attachment deleted)
Reply #14 - May 30th, 2020 at 9:05am
PDF exported from this file renders correctly for us in Adobe Reader and Chrome.
var imp = new ExcelImporter();
imp.View = wbview;
imp.Import("bbb.xlsx", wbview.Workbook);
var activeSheet = wbview.ActiveWorksheet;
pdfExporter.Export(activeSheet, @"D:\test.pdf");
Does the attached PDF work on your side if you open it in Adobe / Chrome? If our file works but yours does not, it might mean PdfExporter's font embedding code fails for some reason when running on your system.
test_pdf.zip (Attachment deleted)
