Page Index Toggle Pages: 1 2 3 [4] 5  Send TopicPrint
Very Hot Topic (More than 25 Replies) how to set wpf spreadsheet export pdf font. (Read 29773 times)
David Chiang
Re: how to set wpf spreadsheet export pdf font.
Reply #45 - Jun 9th, 2020 at 10:13pm
The build files.
Online
Reply #46 - Jun 10th, 2020 at 5:41am
Unfortunately this log is incomplete, and not showing the PDF font markup generated. Please wait for export to finish before attaching. Export a smaller sheet if this one takes too long with all the logging. Or maybe the forum upload did not work correctly, please attach it as a zip if original log is larger than the 66K log.txt showing attached. We need to see this part of the log, if any character there is outside of ASCII character range, the font object will not be encoded correctly in PDF -
using font name MingLiU
/Type /Font
/Subtype /Type0
/DescendantFonts [24 0 R]
/BaseFont /MingLiU
/Encoding /Identity-H
/ToUnicode 26 0 R
/Type /Font
/Subtype /CIDFontType2
/BaseFont /MingLiU
/CIDSystemInfo <<
/Registry (Adobe)
/Ordering (Identity)
/Supplement 0
/CIDToGIDMap/Identity
/FontDescriptor 25 0 R
/DW 1000
David Chiang
Reply #47 - Jun 10th, 2020 at 7:38am
Sorry for sending the incomplete file. I need run from the exe file otherwise it will failed to complete.
yyy.rar (Attachment deleted)
Online
Reply #48 - Jun 10th, 2020 at 7:56am
Attach the log.txt file please. That was the pdf now Smiley We need to see some plain-text PDF objects logged in the txt file, before it gets encoded as bytes in PDF.
David Chiang
Reply #49 - Jun 10th, 2020 at 7:59am
Oh, Sorry
log.rar (Attachment deleted)
Online
Reply #50 - Jun 10th, 2020 at 8:06am
Thanks, so we are still trying to encode Chinese name indeed -
/Type /Font
/Subtype /Type0
/DescendantFonts [20 0 R]
/BaseFont /細明體
/ToUnicode 22 0 R
Probably getting it from System.Drawing.Font used internally by our PdfLib. Our developer will try to fix that today.
Online
Reply #51 - Jun 10th, 2020 at 2:02pm
Please try exporting with this build -
https://mindfusion.eu/_temp/pdf_font_name.zip
Our internal PDF library now calls FontFamily.GetName(0), which returns a "language neutral" name that should work hopefully -
https://docs.microsoft.com/en-us/dotnet/api/system.drawing.fontfamily.getname
David Chiang
Reply #52 - Jun 11th, 2020 at 2:02am
I still get the same result.  Embarrassed
David Chiang
Reply #53 - Jun 11th, 2020 at 2:03am
Here is the log file
log_001.rar (Attachment deleted)
David Chiang
Reply #54 - Jun 11th, 2020 at 6:01am
           private void GenerateRandomFont(ref Cell cell)
                 var style = cell.Style;
                 style.FontName = "MingLiU";
                 style.FontBold = false;
                 style.FontItalic = false;
                 //style.FontSize = 14;
                             for (int k = 0; k < i; k++)
                                   var cell = activeSheet.Cells[k, x + 1];
                                   cell.Data = dataRow[k];
                                   GenerateRandomFont(ref cell);
font for  Spreadsheet
David Chiang
Reply #55 - Jun 11th, 2020 at 6:07am
If I did not use these two lines. Only Chinese characters will not show otherwise none of the display is correct.
                       pdfExporter.AutoDetectEncoding = false;
                       pdfExporter.DefaultEncoding = Encoding.Unicode;
without these code
Online
Reply #56 - Jun 11th, 2020 at 6:16am
Does attached console project display "MingLiU" in English on any line when you run it?
FontNameTest.zip (Attachment deleted)
David Chiang
Reply #57 - Jun 11th, 2020 at 7:05am
Show nothing from the console.  From running your attach program.
Online
Reply #58 - Jun 11th, 2020 at 7:07am
It should open an actual console process and write in its console, not Visual Studio's one. Please run it using Ctrl+F5 and it will pause before closing (F5 alone closes immediately).
David Chiang
Reply #59 - Jun 11th, 2020 at 7:18am
Here it is.
