Hot Topic (More than 10 Replies) Hyperlink Text Coomponent (Read 6519 times)
DSI
May 29th, 2020 at 7:32pm
Is it possible to add a hyperlink text to a custom nodes?
Online
Re: Hyperlink Text Coomponent
Reply #1 - May 30th, 2020 at 8:08am
If you mean ones derived from CompositeNode, try adding a Text component with enableStyledText field enabled, and setting hyperlinks via the <a> tag in this form: "test <a='http://mindfusion.eu'>link</a> test". Alternatively using the button component from https://mindfusion.eu/Forum/YaBB.pl?num=1370616113 open hyperlinks from button's click handler.
DSI
Reply #2 - Jun 3rd, 2020 at 3:07pm
Thanks.  How can I enableStyledText on a composite node?  I am trying to modify Sample Tutorial 8 (...\MindFusion.Diagramming for ASP.NET MVC\ASP.NET MVC 5\Samples\Tutorial8) downloaded from the mindfusion website.  If I google for "enableStyledText" I end up here www.mindfusion.eu/onlinehelp/flowchartnet/index.htm?What_s_New_in_this_Release.h... which looks like it's not the MVC version?
I tried adding it to my json string:
    ""component"": ""Text"",
    ""name"": ""FullName"",
    ""gridRow"": 1,
    ""gridColumn"": 0,
    ""rowSpan"": 2,
    ""columnSpan"": 5,
    ""verticalAlignment"": ""Center"",
    [b]""enableStyledText "": true,[/b]
    ""autoProperty"": true,
    ""text"": ""full name"",
    ""pen"": ""blue"",
    ""padding"": ""1,0,1,0""
and then modifying the node:
Diagram diagram = view.Diagram;
        var node1 = new OrgChartNode();
        node1.Bounds = new RectangleF(25, 15, 60, 25);
        node1.Title = "CEO";
        [b]node1.FullName = "test <a='http://mindfusion.eu'>link</a> test";[/b]
        node1.Details = "Our beloved leader.";
        node1.Frame = "Rectangle";
        node1.Brush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(50, Color.ForestGreen));
        [b]diagram.EnableStyledText(true);[/b]
        diagram.ToolTip("Test");
        diagram.Nodes.Add(node1);
        nodeView.AddNode(node1);
However this is what my node looks like (attached).
Online
Reply #3 - Jun 3rd, 2020 at 4:27pm
There's space in the field name - "enableStyledText ", remove it and it will start parsing and arranging formatted text. Something else is amiss though, a scale flag we usually apply for styled text is not set automatically by CompositeNode, our developer will check in a bit.
Online
Reply #4 - Jun 3rd, 2020 at 4:46pm
For time being you can fix the wrong scale by setting -
node.getComponent("FullName").ignoreTransform = false;
DSI
Reply #5 - Jun 3rd, 2020 at 7:11pm
Is this possible with a ShapeNode or TableNode or ONLY CompositeNode?
DSI
Reply #6 - Jun 3rd, 2020 at 8:10pm
Where would node.getComponent("FullName").ignoreTransform = false; go in my code?
What is attached is what my node looks like now.  I'm assuming the ignoreTransform piece is supposed to fix the fact that only "l" is appearing?  I also cannot click on the text, nothing happens.
Online
Reply #7 - Jun 4th, 2020 at 5:42am
Call setEnableStyledText method on ShapeNode or TableNode and you should be able to embed hyperlinks in same format. We've tested node.getComponent("FullName").ignoreTransform assignment after creating nodes in client-side JS. If you send nodes from server side, you might have to loop and reset this flag after loading them on client. Anyway we'll try to fix that in standard script.
Online
Reply #8 - Jun 4th, 2020 at 12:47pm
With script here it should be enough to set the enableStyledText field -
https://mindfusion.eu/_temp/mvcdiag_hlinks.zip
New assemblies fix some serialization problem with hyperlinks.
DSI
Reply #9 - Jun 4th, 2020 at 7:39pm
Thank you, I still haven't been able to get a click to work on the hyperlink.  I tried putting the node.getComponent("FullName").ignoreTransform in the node creation (image attached) as well as the JS function as suggested (seen below), I think I'm just trying too put it in the wrong space.
function onLoaded(sender, args) {
        diagram = sender;
        args.getNode().getComponent("FullName").ignoreTransform;
        var original = OrgChartNode.prototype.updateCanvasElements;
        OrgChartNode.prototype.updateCanvasElements = function () {
            original.apply(this, []);
            var back = this.getComponent('Frame');
            back.setBrush(this.getBrush());
Please note: i replaced all the files in my project with the ones you attached.
Online
Reply #10 - Jun 9th, 2020 at 7:09am
The control does not follow hyperlinks automatically but just raises an event, this worked in my test with modified template in tutorial3.js -
diagram.addEventListener(
	Events.hyperlinkClicked, onHyperlinkClicked);
function onHyperlinkClicked(sender, args)
    window.open(args.getHyperlink());
You shouldn't have to deal with that ignoreTransform flag anymore if using latest js build, but only set enableStyledText: true in the template. If link's text is still appearing larger than usual, try refreshing the page to update browser's cache.
DSI
Reply #11 - Jun 17th, 2020 at 6:16pm
Thanks.
So here is what the Link text portion of my template (modified tutorial8 MVC solution) looks like:
    ""gridRow"": 1,
    ""gridColumn"": 0,
    ""rowSpan"": 2,
    ""columnSpan"": 5,
    ""enableStyledText"": true,
    ""clickHandler"": ""onHyperlinkClicked""
Here is the JS clickHander Function:
    function onHyperlinkClicked(sender, args) {
This is all part of my Index.cshtml file.  Yet I cannot click on the link.  I have to be missing something.  What do you mean by "the latest js build" and where can I get that?
Online
Reply #12 - Jun 18th, 2020 at 5:57am
I think clickHandler property is something we added for button components? Text does not support it, subscribe to Events.hyperlinkClicked instead as shown in post above.
