Normal Topic Diagramming (Read 4951 times)
Mandy
Diagramming
Jun 10th, 2020 at 11:17am
Here is the project download location : https://drive.google.com/file/d/1oi7vGxbhgSIV0DO2i5loe3lu78GYdIuc/view?usp=shari
ng
There are some questions please advise.
On Page EntitiesDiagram :
The View1 is not arranged but View2 is auto arranged.
a)The void icon will be disappear when TableNode selected in view1.
b)The void icon is not in the correct position in view2.
c)How can I to set the avatar image center alignment and fit in the cell?
d)How to set the links between node Root and node 1055431 is from the bottom of Root to the top of 1055431?
On Page IconDiagram :
How can I to make the IconNode drag and drop?
Thanks!
Lyubo
MindFusion team
Re: Diagramming
Reply #1 - Jun 10th, 2020 at 1:47pm
a) Set Diagram.SelectionOnTop to false to show the attached node when selection is active;
b) Set KeepGroupLayout to true on your layered layout, otherwise the algorithm will try to arrange the attached nodes;
c) You can try a combination of ImageAlign.Fit and ImagePadding with a left margin;.
d) Set ConnectionStyle to TableConnectionStyle.Table on your table nodes
For drag and drop, can you be more specific with your requirements?
Lyubo
MindFusion
Mandy
Re: Diagramming
Reply #2 - Jun 11th, 2020 at 11:00am
Hi Lyubo,
Thank you for your reply it's very helpful.
I would like to disable node's RadialMenu and popup custom page when double click or long press.
Is there possible to handle node double click / long pressed event ?
On IconDiagram :
a)How can i to set the IconNode's font size?
b)Is there possible to drag and move when i tapped on the text?
On EntitiesDiagram :
diagram.NodeClicked += (async (sender,e) => {
                await App.Current.MainPage.DisplayAlert(null, "NodeClicked", "OK");
diagram.NodeSelected += (async (sender, e) => {
                await App.Current.MainPage.DisplayAlert(null, "NodeSelected", "OK");
When i clicked the void icon, it will show 'NodeClicked' and 'NodeSelected' at the same time. I would like to click the void icon then popup 'NodeClick',click other position on the node will popup 'NodeSelected'.
Thanks!
Lyubo
MindFusion team
Re: Diagramming
Reply #3 - Jun 11th, 2020 at 2:10pm
Mandy wrote on Jun 11th, 2020 at 11:00am:
Unfortunately, it's not possible to disable the default context menu, we'll add this possibility in a following release. You could try modifying the existing menu items so they're transparent.
There're no double click or long press events currently, we can try and implement them for a following release. As a workaround, you can use the RadialMenuCreated event to track long press events on nodes (it will fire for right clicks in desktop environments too though). Or you can track subsequent NodeClick events and measure the time it takes in between with a timer to detect double-clicks that way.
On IconDiagram :
To set the IconNode's font size, pass a Font instance with the desired size to the DrawString method in your DrawLocal override. To move the node from the label, you can use EasyMove or InvisibleMove HandlesStyle, but you'll need to make sure the text is within the node's bounds.
You can check the e.Node object in the NodeClicked event if it's a TableNode (the whole node) or a ShapeNode (void icon). NodeSelected will be raise only if the node was previously not selected, so I'm not sure if that would be the correct place to detect clicks. You can use the NodeClicked event for both your cases.
Lyubo
MindFusion
Mandy
Re: Diagramming
Reply #4 - Jun 12th, 2020 at 11:19am
Hi Lyubo,
a)I'm try to setting the menu items to transparent but it seems not to work. What should I do?
I'm setting the Behavior to PanAndModify and set diagram.AllowInplaceDelete and diagram.AllowInplaceEdit to false, but the node still can edited in-place.
b)I'd like to TableNode/IconNode can move, select but cannot edit/delete, which Behavior i should set ?
c)Could you please provide an example for pass the Font to DrawString method, please?
d)The diagram.NodeClicked was not triggered when i click the green area on the  TableNode so i cannot check the e.Node object.
Thanks!
Lyubo
MindFusion team
Re: Diagramming
Reply #5 - Jun 15th, 2020 at 7:12am
Mandy wrote on Jun 12th, 2020 at 11:19am:
Try setting ItemSize and ImageSize on the menu item to Size.Zero. Edit operation won't start that way too.
Modify or PanAndModify behavior with combination of setting EnabledHandles to Move on your nodes should be enough. Alternatively, you can cancel resize modifications from a NodeModifying event handler.
Calling WithSize method on a Font instance will return a new instance of the same font with modified size. Pass that font to the DrawString method. For example:
var font = diagram.Font.WithSize(2);
Handle CellClicked event too. NodeClicked will be raised only when the TableNode is clicked outside of a cell - i.e. the header or the area below the cells.
Lyubo
MindFusion
Mandy
Re: Diagramming
Reply #6 - Jun 15th, 2020 at 11:40am
Hi Lyubo,
Is possible to modify the orange circle to transparent?
Thank you for your help.
Lyubo
MindFusion team
Re: Diagramming
Reply #7 - Jun 15th, 2020 at 12:19pm
You can set the IsVisible flag on the Menu instance to false before exiting from the handler too.
e.Menu.IsVisible = false;
This will hide the selection circle. You may still need use your current code for the items too, otherwise their events may still fire.
Hope this helps,
Lyubo
MindFusion
