Normal Topic How to show the selected node in center of the diagram? (Read 1856 times)
Joost
Jun 28th, 2020 at 3:26pm
Hi, does anybody know how to show the selected node in the center of the diagram?
Lyubo
MindFusion team
Re: How to show the selected node in center of the diagram?
Reply #1 - Jun 29th, 2020 at 6:35am
1) If you want to show the selected node in the center of the current viewport, use the following code:
diagram.NodeSelected += (s, e) =>
  var node = e.Node;
  var dpi = 96; // 96 dpi used just for testing, you'll want the actual device dpi when using this conversion
  var graphics = diagram.CreateMeasureGraphics();
  var viewportHeight = MeasureUnit.Inch.Convert(diagramView.Height / dpi, diagram.MeasureUnit, graphics);
  var viewportWidth = MeasureUnit.Inch.Convert(diagramView.Width / dpi, diagram.MeasureUnit, graphics);
  diagram.ScrollX = node.Bounds.X - viewportWidth / 2 + node.Bounds.Width / 2;
  diagram.ScrollY = node.Bounds.Y - viewportHeight / 2 + node.Bounds.Height / 2;
Please note, that the view will scroll only within the actual diagram bounds, so if the selected node is close to the top or left edge of the document, it won't show in the center. To make sure that doesn't happen, you may want to increase the diagram bounds to ensure enough space between the nodes and the edges.
2) If you wish to actually move the node to the center of the document, and not just set the viewport on it, set its Bounds or use the Move method:
node.Move(diagram.Bounds.Width / 2 - node.Bounds.Width / 2,
    diagram.Bounds.Height / 2 - node.Bounds.Height / 2);
Lyubo
MindFusion
