Normal Topic Application of setting the size of ShapeNode in different events (Read 2119 times)
JackPan
Sep 21st, 2020 at 1:40am
Hi, there. Smiley
I want to change the value of textBoxW or change the value of textBoxH in the TextChanged event to change the width or height of the overlayNode, but when this code is executed, an error will be reported:
var newBounds = new System.Windows.Rect(imageNode.Bounds.Right-overlayNodeWidth , imageNode.Bounds.Bottom-overlayNodeHeight, overlayNodeWidth, overlayNodeHeight);
The error content is: System.NullReferenceException: "The object reference was not set to the instance of the object."
Message=The object reference is not set to the instance of the object.
[Call stack has been truncated]
But this code appears in the textBoxW_PreviewMouseMove event, there is no problem. May I ask why this happens?
private void textBoxW_PreviewMouseMove(object sender, MouseEventArgs e)
            if (isDragging)
                //double newValue;
                System.Windows.Point p = e.GetPosition(this);
                if (p.X > clickPoint.X)
                    if (double.TryParse(textBoxW.Text, out newValueW))
                        newValueW += 0.1;
                    if (double.TryParse(textBoxH.Text, out newValueH))
                        var newBounds = new System.Windows.Rect(imageNode.Bounds.Right - newValueW, imageNode.Bounds.Bottom - newValueH,
                                        newValueW, newValueH);
                        // Change the node's position / dimensions
                        overlayNode.SetBounds(newBounds, true, true);
                        textBoxW.Text = newValueW.ToString();
                else if (p.X < clickPoint.X)
                        newValueW -= 0.1;
                else
                    base.OnPreviewMouseMove(e);
            diagram.InvalidateForeground();
Any assistance would be appreciated.
Cheers,
Jack
Lyubo
MindFusion team
Re: Application of setting the size of ShapeNode in different events
Reply #1 - Sep 21st, 2020 at 4:56am
Is it imageNode that is null? Can't tell from the picture. Make sure that it or the variable that gives you the error is not null when this code runs or null check at the beginning of the method.
if (imageNode == null)
    return;
Lyubo
MindFusion
JackPan
Reply #2 - Sep 21st, 2020 at 5:38am
Thanks very much, Lyubo Smiley
Best regards. Smiley Smiley Smiley
