Normal Topic Set the events of the TextBox as a foreshadowing to control the ShapeNode (Read 3052 times)
JackPan
Sep 21st, 2020 at 1:55am
Hi, there. Smiley
I set the MouseLeftButtonDown event or PreviewMouseLeftButtonDown event to textBoxW in the program, but it only responds to PreviewMouseLeftButtonDown. why?
Any assistance would be appreciated.
Cheers,
Jack
Lyubo
MindFusion team
Re: Set the events of the TextBox as a foreshadowing to control the ShapeNode
Reply #1 - Sep 21st, 2020 at 7:30am
Are you setting Handled to true in your Preview* event? This will stop bubbling and next event won't be raised. Or the event might be consumed somewhere else in the event chain. Why do you need to handle both anyway?
Lyubo
MindFusion
JackPan
Reply #2 - Sep 21st, 2020 at 7:43am
Thanks, Lyubo. Smiley
I did not set Handled to true in the Preview* event. For example:
private void textBoxH_PreviewMouseLeftButtonDown(object sender, MouseButtonEventArgs e)
isDragging = true;
clickPoint = e.GetPosition(this);
private void textBoxH_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
isDragging = true;
The result will only respond to the Preview * event, I didn't handle both, I just want to know why this happens.
Best regards.
Lyubo
MindFusion team
Reply #3 - Sep 21st, 2020 at 7:46am
It could be that the textbox control is consuming the event internally. You can read more on the topic here: https://docs.microsoft.com/en-us/dotnet/desktop/wpf/advanced/routed-events-overv...
Lyubo
JackPan
Reply #4 - Sep 21st, 2020 at 8:53am
Thanks very much, Lyubo. Smiley
So that I have a deeper understanding of the routing events of the wpf control.
Best regards. Smiley Smiley Smiley
