Normal Topic The handle-style and the handle-size of these ShapeNodes (Read 3047 times)
JackPan
Sep 21st, 2020 at 3:00am
Hi, there. Smiley
At present, my program realizes that hold down Ctrl and double click the left mouse button to generate a ShapeNode with a green frame, and hold down Ctrl while holding down the left mouse button, and drag the diagram to generate a ShapeNode with a white frame. But there is a strange phenomenon. After I select the ShapeNode with the green border, the black handle that appears is very large, completely covering the entire range of the ShapeNode, as shown in the screenshot 9_21_8.
1. How to solve it?
2. And because the black-filled handle style will obscure the image of ShapeNode underneath. How can I change the handle style of ShapeNode to the same effect as the screenshot 9_21_4?
ShapeNode that generates a green border:
private void diagram_NodeDoubleClicked(object sender, NodeEventArgs e)
var node = e.Node;
if (node.MasterGroup != null)
node = node.MasterGroup.MainItem as DiagramNode;
var posX = e.MousePosition.X - (diagram.Viewport.X + diagram.Viewport.Width / 2);
var posY = e.MousePosition.Y - (diagram.Viewport.Y + diagram.Viewport.Height / 2);
diagram.ScrollX += posX;
diagram.ScrollY += posY;
if (Keyboard.Modifiers == ModifierKeys.Control)
var cx = e.MousePosition.X;
var cy = e.MousePosition.Y;
var myImage = new BitmapImage(new Uri("../../Resources/Images/Menu/Tranger.png", UriKind.Relative));
rectangle1 = diagram.Factory.CreateShapeNode(cx - 1, cy - 1, 2, 2, Shapes.Rectangle);
rectangle1.Brush = Brushes.Transparent;
rectangle1.Image = myImage;
rectangle1.Stroke = Brushes.Green;
//rectangle1.Text = "R405";
rectangle1.RotateText = true;
double newValue;
double angleValue = 0;
if (double.TryParse(angle.Text, out newValue))
angleValue = newValue;
rectangle1.RotationAngle = angleValue;
rectangle1.StrokeThickness = 0.2;
ShapeNode that generates a white border:
void OnDiagramDoubleClicked(object sender, DiagramEventArgs e)
// hold down the Ctrl key + double-click
var rectangle1 = Diagram.Factory.CreateShapeNode(
cx - 50, cy - 50, 100, 100, Shapes.Rectangle);
Any assistance would be appreciated.
Cheers,
Jack
« Last Edit: Sep 21st, 2020 at 10:08am by JackPan »
Lyubo
MindFusion team
Re: The handle-style and the handle-size of these ShapeNodes
Reply #1 - Sep 23rd, 2020 at 7:39am
You can use the Diagram.AdjustmentHandlesSize property to control the size of the handles, and the various Diagram *HandlesStyle properties to customize the look.
Alternatively you can set nodes' HandlesStyle to Custom and customdraw the handles yourself via the Diagram.DrawAdjustmentHandles event.
Lyubo
MindFusion
JackPan
Reply #2 - Sep 23rd, 2020 at 8:13am
Hi, Lyubo. Smiley
Please don't mind if I continue to ask this question.
My current program creates a behavior class RectanglesBehavior inherited from PanBehavior. How to use the code in this class to implement the Diagram.AdjustmentHandlesSize property to control the size of the handle, and use various Diagram * HandlesStyle to achieve the effect of screenshot 9_21_4.png?
class RectanglesBehavior : PanBehavior
        public RectanglesBehavior(Diagram diagram) : base(diagram, false, true)
            diagram.DoubleClicked += OnDiagramDoubleClicked;
        public override InteractionState StartDraw(Point point)
            Diagram.ModifierKeyActions.Control = ModifierKeyAction.None;
                //return new InteractionState(new ShapeNode(Diagram), null, MindFusion.Diagramming.Wpf.Action.Create);
                var node = new ShapeNode(Diagram);
                node.Brush = Brushes.Transparent;
                node.Shape = Shapes.Rectangle;
                node.Stroke = Brushes.AliceBlue;
                node.StrokeThickness = 0.06;
                return new InteractionState(node, null, MindFusion.Diagramming.Wpf.Action.Create);
            var selected = Diagram.ActiveItem as ShapeNode;
            if (selected != null)
                var handle = selected.HitTestHandle(point);
                if (handle != null)
                    return new InteractionState(selected, handle, MindFusion.Diagramming.Wpf.Action.Modify);
           var rect = NearestRect(point);
           if (rect != null)
                 var handlesStyle = rect.HandlesStyle;
                 rect.HandlesStyle = HandlesStyle.SquareHandles2;
                 var handle = rect.HitTestHandle(point);
                 rect.HandlesStyle = handlesStyle;
                 if (handle != null)
                       return new InteractionState(rect, handle, Action.Modify);
            // return base.StartDraw(point);
            return null;
        /*public override CursorHint SetMouseCursor(Point point, out bool startInteraction)
           return base.SetMouseCursor(point, out startInteraction);
        /*protected override void OnMouseUp(Point mousePosition, MindFusion.Diagramming.Wpf.MouseButton mouseButton)
                 base.OnMouseUp(mousePosition, mouseButton);
        DiagramNode NearestRect(Point point)
            DiagramNode nearest = null;
            double minDist = double.MaxValue;
            foreach (var node in Diagram.Nodes)
                if (node.Locked)
                    continue;
                var dist = DistToRect(point, node.Bounds);
                if (dist < minDist)
                    minDist = dist;
                    nearest = node;
            return nearest;
        double DistToRect(Point point, Rect rect)
            var v = new[]
            new Point(rect.Left, rect.Top),
            new Point(rect.Right, rect.Top),
            new Point(rect.Right, rect.Bottom),
            new Point(rect.Left, rect.Bottom),
            for (var i = 0; i < 4; i++)
                var v1 = v[i];
                var v2 = v[(i + 1) % 4];
                var dist = MindFusion.Utilities.DistToLineSegment(point, v1, v2);
                if (dist < minDist)
                    minDist = dist;
            return minDist;
Best regards.
Lyubo
MindFusion team
Reply #3 - Sep 23rd, 2020 at 9:21am
You don't need to do that from the behavior class, just set the properties of your Diagram instance. For example:
            diagram.AdjustmentHandlesSize = 1;
            diagram.ActiveItemHandlesStyle.HandleBrush = diagram.SelectedItemHandlesStyle.HandleBrush = Brushes.Transparent;
            diagram.ActiveItemHandlesStyle.HandlePen = diagram.SelectedItemHandlesStyle.HandlePen = new Pen(Brushes.Cyan, 0.1);
Lyubo
MindFusion
JackPan
Reply #4 - Sep 28th, 2020 at 7:18am
Thanks very much, Lyubo. Smiley
Smiley Smiley Smiley
Best regards.
