Normal Topic Add node and give bigger name. Drag this node. It causes display issue. (Read 3537 times)
reshma
Sep 21st, 2020 at 11:20am
I have attached file here.
issue regarding when adding big name for the container node and drag this node and change the position that time showing below image issue
« Last Edit: Sep 22nd, 2020 at 1:59pm by reshma »
Online
Re: Add node and give bigger name. Drag this node. It causes display issue.
Reply #1 - Sep 22nd, 2020 at 4:10pm
try this:
ContainerNode.prototype.onUpdateVisuals = function(ctr)
	var rect = ctr.getBounds().clone();
	rect.height = ctr.getCaptionHeight();
	ctr.text.clipPath = new MindFusion.Drawing.Path();
	ctr.text.clipPath.addRect(rect.x, rect.y, rect.width, rect.height);
reshma
Reply #2 - Sep 23rd, 2020 at 6:06am
i am using javascipt i have not found clippath in text and clone of getbound()
Please suggest me what i can use?
Lyubo
MindFusion team
Reply #3 - Sep 23rd, 2020 at 8:40am
Change the function signature to function(ctr: any).
Lyubo
MindFusion
reshma
Reply #4 - Sep 29th, 2020 at 7:23am
above code is working but caption text is showing empty I want to show some text inside in this case.
when I am increasing width that time it is showing text.
if i removed setFoldable(true) then it start to show text but i need this
setFoldable(true).
Can you please suggest me how to show text?'
« Last Edit: Sep 29th, 2020 at 1:30pm by reshma »
Online
Reply #5 - Oct 2nd, 2020 at 9:55am
I can't see that happen in Containers.html example -
container.setText("assemblyexample-test-test-test-test-test");
container.setFoldable(true);
Let me know what should I add to reproduce.
Online
Reply #6 - Oct 2nd, 2020 at 9:59am
Seeing your large caption height, maybe verify you aren't clipping to a smaller rectangle than current caption area. E.g. if you keep original Rect or Path saved somewhere and then text is centered in the larger rectangle but clipped by original one, it will disappear indeed.
reshma
Reply #7 - Oct 12th, 2020 at 4:32am
i used below additional code it works for me
  ctr.text.setBounds(rect);
  ctr.text.fitInBounds = true;
