Normal Topic Docking control crashes (Read 2433 times)
MavinTech
Nov 10th, 2020 at 3:49pm
Using the sample code for UI.DockControl, I loaded it into Visual Studio 2019 and ran the program.  I saved a XML layout that contained a DockWindow with DockItem "Toolbox", and an AutoHideWindow with DockItem "Solution Explorer".  Once that layout was loaded, when I selected the AutoHidden window to "Dock as Tabbed Document", the program crashed.  (See attached)
When I setup the same selections in my code, it crashes there as well.
Re: Docking control crashes
Reply #1 - Nov 11th, 2020 at 3:43pm
We've reproduced this, our developer will investigate.
Reply #2 - Nov 13th, 2020 at 10:30am
This build should fix it -
https://mindfusion.eu/_temp/wpfdock_loadhidden.zip
MavinTech
Reply #3 - Nov 13th, 2020 at 6:18pm
That build fixed the issue.  Thanks for fixing this so quickly.
