Hot Topic (More than 10 Replies) Add button in cell. (Read 9208 times)
David Chiang
Add button in cell.
Dec 17th, 2020 at 8:51am
Is possible too add button in a cell that it can trigger event when click it.
David Chiang
Re: Add button in cell.
Reply #1 - Dec 17th, 2020 at 10:31am
Do you need button to show only for currently active cell, or for a cell on specific position / all cells? For current cell, it could probably be done by inserting a button into the cell-edit UI. For other cases, we'll have to think of something more complex...
David Chiang
Reply #2 - Dec 17th, 2020 at 10:45am
Thanks for the reply. What I need is for adding one or more button for each row of data. When click the button, which will trigger a event to popup a window or some other action. Do you have example to testing... Thanks a lot.
                       for (int x = 0; x < recCount; x++)
                             kk = 0;
                             dataRow = dataTable.Rows[x];
                             for (int k = 0; k < columnsVisible.Count; k++)
                                   //Console.WriteLine("rptExcel 148 : " + " k = " + k + "  datae = " + columnsVisible[k]);
                                   if (columnsVisible[k] == "1")
                                         var cell = activeSheet.Cells[k - kk, x + 1];
                                         //cell.Data =dataRow[k].ToString();
                                         cell.Data = ParsingJson.ConvertParamData(colLinkType[k], colLinkID[k], dataRow[k].ToString(), jsonOther, AboutParam.jsonLang);
                                         GenerateRandomFont(ref cell);
                                   else kk++;
Adding button inside the cell
David Chiang
David Chiang
Reply #3 - Dec 17th, 2020 at 10:56am
Or I can use Hyperlink instead? Any sample.
Reply #4 - Dec 17th, 2020 at 11:02am
Maybe try styling cells themselves to look like hyperlinks or buttons, and then run your action from CellClicked event. If you need actual buttons, we could extend the embedded objects system (e.g. images / annotations) to support custom controls for next release.
Reply #5 - Dec 17th, 2020 at 11:06am
David Chiang wrote on Dec 17th, 2020 at 10:56am:
You can find hyperlinks used in ReadyWorkbooks example, implementing a table of contents. You could intercept hyperlink clicks via WorkbookView.HyperlinkClicked event handler.
David Chiang
Reply #6 - Dec 17th, 2020 at 11:29am
Any example by code behind? Like sample code I put.  How to WorkbookView.HyperlinkClicked popup new window?
David Chiang
Reply #7 - Dec 17th, 2020 at 11:41am
activeSheet.Cells["A1"].SetHyperlink(HyperlinkType.WebAddress, "1", "");
workbookView.HyperlinkClicked +=
    (sender, args) => MessageBox.Show(args.Cell.Value.ToString());
David Chiang
Reply #8 - Dec 17th, 2020 at 12:01pm
Here is code I used.
                                         cell.SetHyperlink(HyperlinkType.WebAddress, ParsingJson.ConvertParamData(colLinkType[k], colLinkID[k], dataRow[k].ToString(), jsonOther, AboutParam.jsonLang), "");
But I am not able to close the messagebox. It keep pop up.
it will popup 5302 times
                                               (sender, args) => showWindow();
           void showWindow()
                 Console.WriteLine("KKK");
if I only use
the data will not show up.
David Chiang
Reply #9 - Dec 17th, 2020 at 6:15pm
That's some patience to count them all Wink Sounds like you've attached the event handler 5302 times - are you maybe looping over all rows and calling HyperlinkClicked += code for each one? In such case, try moving that outside of the loop. I.e. not like this -
foreach (row...)
    // set hyperlink
but like this
foreach (row...)
    // set hyperlink
David Chiang
Reply #10 - Dec 18th, 2020 at 12:51am
Thanks a lot Cheesy, any sample to make the cell style like button? Since I like to hide data in behind, Usually I use TAG but there is no TAG attribute in cell. Is there any place I can hide the data?
BTW. How to show the long number to string instead of 1.3434+12?
Is there anyway I can do like
                                               cell.SetAnnotation(dataRow[k].ToString());
cell.SetAnnotation.Visibility = Visibility.Hidden ;
Or How do I  inserting a button into the cell-edit UI? Any sample for that.
Thanks again
David Chiang
« Last Edit: Dec 18th, 2020 at 7:11am by David Chiang »
Reply #11 - Dec 18th, 2020 at 11:27am
There's a Row.Tag property you could use to store custom data. Since you'll have one button / link per row, maybe that's enough?
If you need to associate data with individual cells, maybe use Excel's approach where people keep misc. data in separate worksheet. E.g. you could also set that worksheet's Visible property to false to hide it from users.
Reply #12 - Dec 18th, 2020 at 11:38am
Try setting cell's Style.Format to one different than General, e.g. "0".
Reply #13 - Dec 18th, 2020 at 11:51am
You could set some background and border in cell's Style to make it look (a bit) like a button, e.g. as in attached screenshot. If you need a more elaborate appearance than that, we'll have in mind some custom drawing or embedding actual buttons for next release.
David Chiang
Reply #14 - Dec 18th, 2020 at 11:58am
Thanks for the reply. The cell format is working now and I might have more then one button per ROW. How can I inserting a button into the cell-edit UI? That I can use button's TAG to hide the data. Any sample for that.
Or the about answer is the way to do?
Thanks a lot
David Chiang
