We are having a couple of issues using the fromJson method on the client side. Here is an example scenario:
1. User moves a node, which fires the onNodeModified event handler.
2. In that handler, we do an AJAX call that sends data, including the diagram as a JSON object to the server.
3. On the server, we modify the tag of the node that was modified and then send the diagram back as JSON to the client side.
4. Back on the client side in the success function of the AJAX call, we redisplay the diagram (sender.fromJson(diagramJson)) so that it is up to date for the user to interact with.
5. We see 2 issues not just with the node modified event, but with others as well:
A. The map flickers on the user's screen. It is very noticeable on slower connection speeds.
B. The original event fires a second time, so in this scenario that is onNodeModified, but we are seeing it with other events as well, such as link deleted, link modified, etc. This all means the map flickers twice as it reloads twice.
How can we resolve issues A and B?
Client side code:
function onNodeModified(sender, args) {
$.ajax({
type: "POST",
url: "@Url.Action("NodeModified", "Test")",
data: { diagramJson: sender.toJson(), nodeJson: JSON.stringify(args.node.toJson()), nodeTag: JSON.stringify(args.node.tag },
dataType: 'json',
success: function (result) {
console.log("node modified");
//Redisplay diagram
sender.fromJson(result.success);
Controller method:
[HttpPost]
public ActionResult NodeModified(string diagramJson, string nodeJson, string nodeTag)
DiagramView view = DiagramView.FromJson(diagramJson);
Diagram diagram = view.Diagram;
JavaScriptSerializer jsSerializer = new JavaScriptSerializer(new ItemTypeResolver(null));
jsSerializer.RegisterConverters(new JavaScriptConverter[] { new ShapeNodeConverter(view) });
ShapeNode modifiedNode = jsSerializer.Deserialize<ShapeNode>(nodeJson);
CustomTag modifiedTag = JsonConvert.DeserializeObject<CustomTag>(nodeTag);
modifiedTag.XLocation = (int)modifiedNode.Bounds.X;
modifiedTag.YLocation = (int)modifiedNode.Bounds.Y;
List<DiagramNode> matchingNodes = diagram.Nodes.ToList().FindAll(a => a.Id.Equals(modifiedNode.Id));
foreach (DiagramNode node in matchingNodes)
int nodeIndex = diagram.Nodes.ToList().FindIndex(a => a.Equals(node));
node.Tag = modifiedTag;
diagram.Nodes.ToList().RemoveAt(nodeIndex);
diagram.Nodes.ToList().Add(node);
view.Diagram = diagram;
return Json(new { success = DiagramView.ToJson(view) });
Thanks.
