Hot Topic (More than 10 Replies) after updation of 3.5.2 version facing issues table node cell issue (Read 5235 times)
reshma
Feb 25th, 2021 at 2:01pm
I am using table node and in this table node cell i am showing text data earlier i was showing correct but after updating of 3.5.2 version showing compress text as i have attached image below.
« Last Edit: Feb 26th, 2021 at 7:13am by reshma »
Re: after updation of 3.5.2 version facing issues
Reply #1 - Feb 26th, 2021 at 7:07am
The screenshot looks correct for what you'd get if using resizeToFitText's keepCellWidth option and cell labels don't fit on a single line. Maybe whatever old version you were using wasn't implementing that option correctly.
reshma
Re: after updation of 3.5.2 version facing issues table node cell issue
Reply #2 - Feb 26th, 2021 at 7:16am
i have updated correct image above issue is like text is getting compress in new version and earlier old version showing proper text.
Please check above image
Reply #3 - Feb 26th, 2021 at 7:43am
Please post the code you use to create tables.
reshma
Reply #4 - Feb 26th, 2021 at 11:55am
Please find below snippet of code, which we are using to create a table node.
const nfNode: TableNode = this.diagram.getFactory().createTableNode(100, 160, width, height);
nfNode.setEnableStyledText(true);
nfNode.redimTable(colCount,  rowCount);
nfNode.setAllowResizeColumns(true);
nfNode.resizeToFitText(false, true);
Reply #5 - Mar 1st, 2021 at 9:01am
From what we can tell, table.resizeToFitText never worked correctly with enableStyledText and keepCellWidth options enabled. It doesn't actually keep the column widths, but applies them as a limit while usually shrinking the columns. Anyway that incorrect logic interferes with some padding calculations we added recently and becomes visible with your larger texts. Our developer will try to fix that in next couple of days.
Reply #6 - Mar 2nd, 2021 at 1:18pm
This build should fix that -
https://mindfusion.eu/_temp/jsdiag353.zip
reshma
Reply #7 - Mar 10th, 2021 at 5:47am
Thank you for your efforts, but still there is a issue with text wrapping.
Attaching screen shot for the same.
Reply #8 - Mar 10th, 2021 at 6:25am
Please attach json file created by Diagram.toJson().
reshma
Reply #9 - Mar 10th, 2021 at 9:25am
Please find json file.
diagram_toJSON.json (Attachment deleted)
Reply #10 - Mar 10th, 2021 at 4:54pm
I've replaced tutorial1.js code with this and text looks rendered correctly -
var Diagram = MindFusion.Diagramming.Diagram;
var diagram;
$(document).ready(function ()
	diagram = Diagram.create($("#diagram")[0]);
	$.get("diagram_toJSON.json", onResponse);
function onResponse(json)
    if (json)
        diagram.fromJson(json);
        for (var node of diagram.nodes)
            if (node.resizeToFitText)
                var height = node.rows[0].height;
                node.resizeToFitText(false, true);
                console.log("change: " + String(node.rows[0].height - height));
The JSON file doesn't seem to contain image cells while your screenshots were showing images. If you are doing some form of custom-drawing for the images and resetting cell.text.bounds to fit them, you will also need to adjust cell sizes after calling resizeToFit.
Otherwise make sure you aren't changing column sizes, font size, text or padding properties after the resizeToFit call.
« Last Edit: Mar 16th, 2021 at 2:59pm by Slavcho »
JavaScript.zip (Attachment deleted)
reshma
Reply #11 - Mar 12th, 2021 at 11:41am
We tried with the given snippet of code but its not working.
As per the requirements we need images in cells but we are not
resetting the cell.text.bounds anywhere.
We tried to remove column sizes properties after the resizeToFit call even tough we need it for some specific requirement.
But unfortunately it didn't work.
We observed after removing "node.setEnableStyledText(true)" its working fine but in that case its not wrapping the caption text.
Please find attached screen shot.
Reply #12 - Mar 12th, 2021 at 12:09pm
Please modify the JavaScript.zip above to reproduce that and attach it back.
