Normal Topic NodeListView caption appearing behind icon (Read 3494 times)
PLM Doctor
Mar 10th, 2021 at 2:12pm
I am trying a version of the TreeLayout sample. The caption is appearing behind the icon (see screen capture). I do not see any NodeListView members that would allow anchoring or repositioning of the caption. It seems like the caption should automatically anchor to the side of the caption. Am I missing something?
Re: NodeListView caption appearing behind icon
Reply #1 - Mar 10th, 2021 at 5:32pm
Please post your NodeListView initialization code. Captions show correctly in my test if I just set them in addNode call.
PLM Doctor
Reply #2 - Mar 13th, 2021 at 4:17pm
That is what is so perplexing for me. When it comes to the Mindfusion calls, I am not seeing any difference. So it is working for you. I guess I need to see if I can get the sample to work as-is and go from there.
           // non-drug printed components
           var node = new MindFusion.Diagramming.ShapeNode(compList);
           node.setShape("Rectangle");
           node.setImageLocation('ux/images/carton.png');
           compList.addNode(node, 'Carton');
           // drug products
           if (drgprdMap != null){
                 for (const [dp, attrMap] of Object.entries(drgprdMap)){
                       if (attrMap.container == 'VIAL'){
                             node.setImageLocation('ux/images/vial.png');
                       else if (attrMap.container == 'SYRINGE'){
                             node.setImageLocation('ux/images/syringe.png');
                       else if (attrMap.container == 'BOTTLE'){
                             node.setImageLocation('ux/images/bottle.png');
                       node.setText(dp);
                       compList.addNode(node, dp);
Reply #3 - Mar 15th, 2021 at 7:15am
What version of the library are you using? Have you changed anything in the listview's html code?
PLM Doctor
Reply #4 - Mar 15th, 2021 at 3:42pm
We are using version 3.5.1.
This is the div we have for the NodeListView panel. The parent panel width is 170.
<div style="position: absolute; top: 0px; bottom: 0px; right: 0px; width: 160px; overflow: hidden; height: 100%"><canvas id="compList"></canvas></div>
Reply #5 - Mar 16th, 2021 at 10:06am
We could not reproduce with v3.5.1 either. Please modify attached TreeLayout.zip to show the problem and post it back.
TreeLayout.zip (Attachment deleted)
PLM Doctor
Reply #6 - Mar 19th, 2021 at 2:40am
I replaced the MindFusion.Common.js and Mindfusion.Diagraming.js with the ones in the example and that fixed the problem. Verified by substituting with original libraries and problem returned. I wonder what version I actually have?
Interesting.... the libraries in versions 3.5.1, 3.5.3 and the attachment did not work. Only the ones in the example.
Reply #7 - Mar 19th, 2021 at 6:53am
The scripts in this example are from v3.5.1 in our release archive, you should get the same files if you download the version from your account page. I can't remember if we ever sent you a pre-release version in the past to fix other issues, if so it might have this problem in NodeListView. Otherwise we can't see any changes in our source control since v3.5.1 that could lead to this - make sure browser is not using cached scripts when you try with latest v3.5.3, or please attach your code reproducing that.
