Normal Topic cell data keep leading 0s (Read 6276 times)
David Chiang
May 6th, 2021 at 4:38am
Sorry to ask a simple question. I try to search the answer but no luck. Thanks in advance. How to keep format number as string to keep the leading 0s. When insert data in the cell, it will truncate the leading 0s and leave only rest of number in the cell.
David Chiang
Re: cell data keep leading 0s
Reply #1 - May 6th, 2021 at 7:04am
You could set cell's Style.Format to something like "00000.000" to show a fixed number of leading and trailing zeros. It might be possible to count entered zeros in InplaceEditEnding event handler to set format automatically if you'd like to preserve them exactly. Users could also start a numeric value with ' as in Excel to treat it as text, which will preserve exactly entered string, but then won't be able to use it in formulas.
David Chiang
Reply #2 - May 7th, 2021 at 5:07am
Got it, Thanks
David Chiang
