Normal Topic Selecting diagram bounds and not selecting nodes on it! (Read 3108 times)
MikeHeal
May 12th, 2021 at 11:24pm
I am trying to implement zooming in on the diagram using Shift key continuously pressed and mouse drag (mouse dragged with left key pressed, and released, to zoom into selected area).
Here when we keep Shift pressed i want only the blue selection box to appear, and None of the nodes on the diagram should get selected and it should also Not allow link creation at this time.
I tried:
diagram.KeyDown += OnDiagramKeyDown;
diagram.KeyUp += OnDiagramKeyUp;
diagram.MouseUp += OnMouseUp;
void OnDiagramKeyDown(object sender..
if (Keyboard.Modifiers == ModifierKeys.Shift)
shiftPressed = true;
diagram.Behavior = Behavior.SelectOnly; // ! doesn't help.
void OnDiagramKeyUp(object sender, KeyEventArgs e)
if (e.Key == Key.LeftShift || e.Key == Key.RightShift)
isShiftPressed = false;
diagram.Behavior = Behavior.DrawLinks;
private void OnMouseUp(object sender, MouseButtonEventArgs e)
if (isShiftPressed)
diagram.ZoomToRect(diagram.Selection.Bounds, true);
The zooming is fine but, even though the diagram Behavior is set to 'SelectOnly' the nodes also gets selected, that i am not looking for. Huh . Any help is appreciated. Thanks a lot.
Online
Re: Selecting diagram bounds and not selecting nodes on it!
Reply #1 - May 13th, 2021 at 10:37am
Note that changing Behavior values clears selection too. You can avoid it along with item selection like this -
diagram.ModifierKeyActions.Shift = ModifierKeyAction.Select;
bool isShiftPressed = false;
Rect zoomToRect = new Rect();
void OnDiagramKeyDown(object sender, KeyEventArgs e)
	isShiftPressed = Keyboard.Modifiers == ModifierKeys.Shift;
	if (isShiftPressed)
		diagram.ZoomToRect(zoomToRect, true);
void OnNodeSelecting(object sender, NodeValidationEventArgs e)
	e.Cancel = isShiftPressed;
	zoomToRect = diagram.Selection.Bounds;
void OnLinkSelecting(object sender, LinkValidationEventArgs e)
You could also try adapting the ZoomTool code here from our WinForms API to WPF -
https://mindfusion.eu/Forum/YaBB.pl?num=1290792836/1#1
MikeHeal
Reply #2 - May 13th, 2021 at 3:28pm
Thank you , that did the trick.
MikeHeal
Reply #3 - May 13th, 2021 at 7:11pm
One more question, if you don't mind.
While testing I noticed, when i use ZoomToRect(diagram.Selection.Bounds) , while zooming it captures all selected items.
(Related issue: https://mindfusion.eu/Forum/YaBB.pl?num=1259167870)
What can i do to zoom only to the selection blue box, and selection should come to center of the diagram screen!?
Thanks again.
Online
Reply #4 - May 14th, 2021 at 5:54am
That's why using "zoomToRect" in code above, I guess you have omitted that part? Selection.Bounds matches the lasso coordinates while it's being drawn, i.e. during validation events like the xxSelecting ones, but it's set to the union of selected nodes' bounds when you finish drawing. This will be more apparent if you change Selection.Style to Frame.
MikeHeal
Reply #5 - May 14th, 2021 at 4:09pm
Thanks.
I have used diagram.Selection.Bounds like this:
private void OnMouseUp(object sender, MouseButtonEventArgs e){
if (isShiftPressed)
diagram.ZoomToRect(diagram.Selection.Bounds, true); // doesn't work on selection area
The above doesn't zoom the selected blue box. For example, if there is a link (that stretches end to end) and a node under the selection, then the diagram just zooms slightly enough to accommodate the link and node.
Online
Reply #6 - May 17th, 2021 at 6:02am
So save the Selection.Bounds value reported during Selecting event handlers, as shown with the 'zoomToRect'  field in our code above, and it should zoom as expected. Alternatively use a temporary node with dashed border and transparent fill for drawing the lasso, and DrawNodes behavior instead of SelectOnly.
Online
Reply #7 - May 17th, 2021 at 6:57am
Our developer has added a built-in zoom behavior here -
https://mindfusion.eu/_beta/wpfdiag363.zip
		diagram.Behavior = Behavior.Zoom;
You can customize zoom-selection's appearance from new InitializeLasso event handler -
void OnInitializeLasso(object sender, SelectionEventArgs e)
	e.Selection.Stroke = Brushes.Red;
MikeHeal
Reply #8 - May 18th, 2021 at 12:37am
Thanks for the reply & updates.  Smiley
I couldn't verify it now; currently my organization is using version 3.6.1.450 dll's. So, if these are part of your next release cycle, I can use it then!
Online
Reply #9 - May 18th, 2021 at 10:41am
Yep, we should be releasing this next week.
