Normal Topic ExcelExporter (Read 4987 times)
cgay1
ExcelExporter
Jun 3rd, 2021 at 1:22pm
When attempting to Export a Workbook into Excel format with the ExcelExporter, if the file is already open it fails.  I notice in the output window that an error is generated, however, the ExcelExporter does not raise/throw the error:
java.io.FileNotFoundException: C:\MapEx\Results.xlsx (The process cannot access the file because it is being used by another process)
How can my program capture the error so I can prompt the user to close the file?
Re: ExcelExporter
Reply #1 - Jun 4th, 2021 at 7:22am
ExcelExporter and CalcExporter from this build rethrow all IOExceptions -
https://mindfusion.eu/_temp/jpack_ioex.zip
