Normal Topic Diagramming for WPF, V3.7 (Read 2654 times)
Jul 19th, 2021 at 11:16am
We have released version 3.7 of WPF Diagram control. It contains the following new features and improvements:
SVG nodes
The SvgNode class represents nodes that display SVG drawings, in addition to the rendering provided by the base ShapeNode class. A node's SVG drawing is rendered after its associated bitmap Image. Set the Transparent property of base type to hide the node's Shape geometry and draw only SVG graphics. The SVG drawing that should be shown inside an SvgNode is specified through the node's Content property. SVG graphics are loaded and associated with the node through an SvgContent object, which should be initialized and then assigned to this property.
Import diagrams from SVG
The SvgImporter class allows importing Scalable Vector Graphics files (*.svg) into MindFusion.Diagramming. Each top-level SVG group element is imported as a separate SvgNode, whose Content is set to the group's child elements. If the SVG file was exported from Visio or OpenOffice Draw, SvgImporter will create DiagramLink objects for groups it recognizes as connectors in order to recreate the original diagram model, though in this case it will not preserve fully the original appearance of connectors in SVG.
Code 128 barcodes
BarcodeNode now supports barcodes in code 128 format.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
