Normal Topic How-to: Set line-height style for ShapeNode text ! (Read 2226 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Sep 8th, 2021 at 1:38pm
I've created a shape node like below. May I know how to set line-height style for the text set in that shape node, either in this code block or css?
  private createTextNode() {
    var text = "The diagram-view Angular component allows integrating the MindFusion.Diagramming API into Angular applications. It renders a Diagram instance assigned to diagram property as its model.";
    var node = new ShapeNode(this.diagram);
    node.setBounds(new Rect(1100, 100, 170, 20));
    node.setText(text);
    node.setFont(new Font("Times New Roman", 15, false, false, false));
    node.setBrush("white");
    node.setEnableStyledText(true);
    node.setTextAlignment(Alignment.Near);
    node.setShadowColor("transparent");
    node.resizeToFitText(common.Diagramming.FitSize.KeepWidth);
    node.setAllowIncomingLinks(false);
    node.setAllowOutgoingLinks(false);
    this.diagram.addItem(node);
Kannan
Lyubo
MindFusion team
Re: How-to: Set line-height style for ShapeNode text !
Reply #1 - Sep 9th, 2021 at 8:02am
There's no out-of-the-box support for that, but it can be achieved by overriding the Text.drawStyledText method and increasing the line-height there.
For example:
Code (Javascript)
var originalDrawStyledText = MindFusion.Drawing.Text.prototype["drawStyledText"];
MindFusion.Drawing.Text.prototype["drawStyledText"] = function (context, sequences, layoutRect, halign, valign)
    this.lineHeight += 4; // adjust the line height here
    originalDrawStyledText.apply(this, [context, sequences, layoutRect, halign, valign]);
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #2 - Oct 19th, 2022 at 5:50am
When I set a long single word (without space) whose length is more that the width of the shape node, it was not wrapping (like in Shape Node-1.png attached).
To fix that I used the below code,
After that the text is wrapped as shown in the attached image Shape Node-2.
But when I enter "<" symbol in between, characters after that is not shown. In the attached screen Shape Node-2, only first four characters are shown. The "<" symbol is included in the fifth position.
May I know how to solve these issues?
Kannan
Reply #3 - Oct 19th, 2022 at 7:52am
enableStyledText switches to HTML parsing. Try escaping the < sign as &lt;
Kannan Thirumal
Senior Member
Reply #4 - Oct 21st, 2022 at 2:08pm
That works Slavcho! Thanks!
