Hot Topic (More than 10 Replies) Chinese language is not supported in MindFusion.Diagramming.WebForms.DiagramView (Read 6275 times)
Selvam
Oct 20th, 2021 at 9:48am
Kindly suggest/provide solution to how to define Chinese language in the node text.
Re: Chinese language is not supported in MindFusion.Diagramming.WebForms.DiagramView
Reply #1 - Oct 20th, 2021 at 11:37am
This works in my test with default font.
void TestChinese(Diagram diagram)
    var node = diagram.Factory.CreateShapeNode(20, 20, 30, 30);
    node.Text = "� �题";
Have you set some specific font as property of nodes or styles?
Selvam
Reply #2 - Oct 25th, 2021 at 11:17am
we are using by suggested code but it displays like some character [Refer Attachment1].
If we are using below code then it will be displayed as exact character [Refer Attachment2]. but while downloading as PDF the same text is not displayed [Refer Attachment3].
startNode.EnableStyledText = true;
startNode.PolygonalTextLayout = true;
Kindly suggest for this
Attachments.zip (Attachment deleted)
Reply #3 - Oct 25th, 2021 at 12:41pm
Try either setting the NoFontFallback flag in nodes' TextFormat.FormatFlags to zero, or explicitly setting Font to one that contains Unicode characters.
For PDF see https://mindfusion.eu/Forum/YaBB.pl?num=1277702629/10#10
Selvam
Reply #4 - Oct 27th, 2021 at 7:05am
Hi Slavcho,
I think still we are missing something to get exact text while downloading.
we have used be code and diagram displays like ?? in downloaded PDF.
AutoDetectEncoding = false,
DefaultEncoding = System.Text.Encoding.Default
Reply #5 - Oct 27th, 2021 at 7:46am
Have you tried Unicode encoding as in post linked above?
Selvam
Reply #6 - Oct 27th, 2021 at 11:17am
Hi Slavcho,
Question mark value is displayed when using Encoding.Default code [Ref Att1.png]
Empty value is displayed when using Encoding.Unicode code [Ref Att2.png]
Reply #7 - Oct 27th, 2021 at 3:35pm
What happens if you remove the encoding properties? They might not be needed after you fixed on-screen rendering.
diagram.Factory.CreateShapeNode(10, 10, 40, 40).Text = "地狱其他凝胶";
var pdfex = new PdfExporter();
pdfex.Export(diagram, @"D:\test.pdf");
With that I'm seeing Chinese text in both Firefox and Edge, while Adobe Reader asks to download a font pack. On what OS are you seeing missing fonts? I believe that's what the question marks indicate.
Selvam
Reply #8 - Oct 28th, 2021 at 8:41am
we are using Windows 10 Pro OS
Is required to install Chinese font?
Reply #9 - Oct 28th, 2021 at 9:12am
You might need fonts both on server side for PdfExporter to use and on client side for PDF readers. Does attached PDF render correctly for you? Please attach your PDFs generated with and without encoding overrides and I will check them on my system.
test_003.pdf (Attachment deleted)
Selvam
Reply #10 - Nov 8th, 2021 at 4:39pm
Hi Slavcho,
I have attached the sample code. PFA
Refer PDF under the temp folder which is not displayed exact char what is used in the application.
Kindly refer the code and suggest us.
SampleWebSite.zip (Attachment deleted)
Reply #11 - Nov 10th, 2021 at 9:01am
PDF generated on our side with default AutoDetectEncoding = true value looks correct. Does attached file render Chinese glyphs for you?
var pdf = new MindFusion.Diagramming.Export.PdfExporter
    PageSize =
        (PageSize)
            Enum.Parse(typeof(PageSize), diagramSize, false),
    Margins = { Bottom = 2, Top = 2, Left = 2, Right = 2 },
    InvisibleItems = true,
    AutoScale = MindFusion.Diagramming.Export.AutoScale.FitToWidth,
	//DefaultEncoding = System.Text.Encoding.Unicode,
If AutoDetectEncoding = true generates a different PDF for you, please attach it and our developer will compare with ours to investigate what might be going wrong. From what we can tell, the PDFs from your temp folder were generated with auto-detect disabled.
db18b624-388d-414e-8099-83ac2f1fc712_E.pdf (Attachment deleted)
Selvam
Reply #12 - Nov 24th, 2021 at 11:20am
Hi Slavcho,
While opening the PDF which attached by you in this thread it will display font package required notification in Adobe. and same issue exist with viewing in chrome browser
Refer the attach-1 and after clicked ok refer the attach-2
Reply #13 - Nov 24th, 2021 at 4:51pm
Adobe's font pack page was working for me the other day, and the PDF shows on my side after installing from there; maybe try updating your PDF Reader version in case they've obsoleted some URL used by old ones.
As for Chrome, it might be falling back to fonts without glyphs if it can't find the actual ones from the PDF file. Try opening the PDF in notepad and look for /FontName PDF tags. It should render correctly when you have these fonts installed on client's OS.
