Normal Topic Not able to view diagram (Read 3132 times)
Selvam
Dec 10th, 2021 at 7:02pm
Hi Team,
We are getting out of memory exception while generating diagram like one value pointing to other value.
Refer Attachment OutOfMemory-Error and also attached sample application.
Kindly suggest to avoid error.
DTProcessFlowDiagram.zip (Attachment deleted)
Re: Not able to view diagram
Reply #1 - Dec 13th, 2021 at 9:42am
There might be millions of paths in larger graphs. Try new EnumAllPaths method here, it immediately yields each found path instead of collecting them all in a list -
https://mindfusion.eu/_temp/netdiag_enumpaths.zip
Otherwise use the FindAllPaths overload that takes maxPaths argument to limit the number of collected paths.
